Heated grips died - replace or move on? - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-04-2012, 10:07 PM   #11 (permalink)
Well West Texas can get damned cold at night, might roast you during the day though.
Old 12-04-2012, 10:15 PM   #12 (permalink)
I did a quick search and found nothing relative to heated grips failing. Can anyone point me in the right direction?
They seem relatively simple items and I'm wondering WTF is failing on them. If it's the actual heating elements causing the problem seems that would be an easy fix.
Was actually considering getting some now I have to wonder.
Old 12-04-2012, 11:26 PM   #13 (permalink)
Dr Volts
Dutch1's Avatar
Put 2 years and 25,000 k on the heated grips I installed (myself) on my 2010 Classic.
It's almost a 3 hour job.
Best money I spent on the whole bike.
Dutch1 is offline   Reply With Quote
Old 12-05-2012, 05:10 AM   #14 (permalink)
Imperial Wizard...
lakeforktx's Avatar
Fug heated grips...I want some heated socks....
2012 Ultra Classic White hot Pearl..... 2002 Fatboy Concord Purple,
lakeforktx is online now   Reply With Quote
Old 12-05-2012, 05:28 AM   #15 (permalink)
GlideWide's Avatar
Hey buddy, my pops put apes on his 12 limited. They couldnt fit his heated grips and they are the stock harley grips that came on the touring models. Let me know if you would like them and I will work out a deal for ya
GlideWide is online now   Reply With Quote
Old 12-05-2012, 07:02 AM   #16 (permalink)
SCHMIDTYS's Avatar
Check the grip fuse, if that's okay then test the grips with an ohm meter. In other words make sure the grip's elements are actually shot and the wiring isn't culprit. An open in the grip's circuit will cause them to not heat.
Old 12-05-2012, 07:38 AM   #17 (permalink)
Baldy Locks's Avatar
Just like Schmidtys said test with a meter, if its still at the shop they (hopefully) should be able to ohm them out. Make sure they aren't connected tho because then you will read ohms of the other thru the wires.
There's no cure for dumb but it sure thins the herd
Baldy Locks is offline   Reply With Quote
Old 12-05-2012, 07:55 AM   #18 (permalink)
jahn's Avatar
Images: 3
Got heated grips for a Nightster 4 years ago, spoiled me so Softail has had them for 1 1/2 years. Use them in the spring, fall, and winter. Really have spoiled me. No problems, no failures yet. In line fuse can corrode contacts in damp weather or with condensation. have used silicone or bulb grease lightly on all fuse contacts for 2 years and no further fuse issues. For really cold, long rides, under 40 for several hours have heated gloves and jacket liner. Guess that makes me a couch dog, but I stay happy and warm...
jahn is offline   Reply With Quote
Old 12-05-2012, 07:57 AM   #19 (permalink)
huskerbob's Avatar
Fug heated socks...I want some heated jockey shorts....
huskerbob is offline   Reply With Quote
Old 12-05-2012, 09:33 AM   #20 (permalink)
windwalker's Avatar
Images: 6
Amen to that!!!
1991 FLSTC
Why drive, when you could ride?
See ya' round the bend!
Lookin' for crucial velocity.
windwalker is offline   Reply With Quote
