Rev tech outer primary? - Page 3 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 12-11-2012, 05:34 PM   #21 (permalink)
S3ven's Avatar
Originally Posted by SCHMIDTYS View Post
That's easy ! Only two holes in the inspection cover are threaded, the two short screws. The long screws thread into the inner standoffs in the inner primary I was referring to earlier.
My inner primary does not appear to have standoffs to accept the longer bolt needed to use the outer with only two threaded holes. None of the above mentioned retailers could identify which of the 3 hole covers was for which application. I'm sorry if I come off as an ingrate.
S3ven is offline   Reply With Quote
Old 12-11-2012, 05:44 PM   #22 (permalink)
SCHMIDTYS's Avatar
I didn't say you were an ingrate, I just said I give up. All the part numbers I threw at you and the rest of the info I gave you should have gotten you on the right track. Did you try calling Bill's Custom Cycles ? They are the gurus at what fits what man.
Old 12-11-2012, 05:51 PM   #23 (permalink)
S3ven's Avatar
I was referring to links comment.
You definitely got me on the right track. I will call bills when I get off work.
Old 01-09-2013, 08:47 PM   #24 (permalink)
S3ven's Avatar
In case anyone stumbles upon this topic in the future the correct outer primary for a gen III revtech 110" is a Harley softail '89-'93.
