Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > General Forum > General Motorcycle related
Old 07-02-2009, 09:14 PM   #41 (permalink)
kc5gxc's Avatar
I am interested in this and want to relate an oil experience. Had a car with a bad lifter (a Pontiac of course) . Running 20w50 worked ok, but on a long trip, the lifter would start clicking...louder and louder and eventually, it would lose all prime or pressure and I would get a dead miss on that cylinder...............If I ran straight 40 wt in engine, on the same trip, I would get some clicking, but never lose the cylinder. I can only conclude the obvious.
However....I am running 20w50 Castrol in the Sportster on days of 102 deg. here in MS.
NO traffic, however, just in rural roads or interstate. If I had stop and go and traffic driving in this heat, I would go to straight 50 for sure.
Good Luck...........Pete
2005 Sportster XL883C
Poplarville, MS
kc5gxc is offline   Reply With Quote
Old 07-02-2009, 10:55 PM   #42 (permalink)
Appalachian American
XDixiecratX's Avatar
Ok anything wrong with a quart and a half of 20w-50w and a quart and a half of straight 50w , or is it better not to mix oils
XDixiecratX is offline   Reply With Quote
Old 07-02-2009, 11:39 PM   #43 (permalink)
In Tejas, dino oils tend to break down at the higher temps that v-twin air cooled engines typically run at in the summer. That is the main reason true synthetics are used in this environment. Lots of people use dino oils in the Tejas heat, but for my money I want something that adds an extra 30-50 degree protection that synthetics offer. Beside that, I get a real kick out of paying somebody $10.00 a quart for synthetics.
texaswiz is offline   Reply With Quote
Old 07-03-2009, 07:20 AM   #44 (permalink)
Mentally unstable.
Hmmmmm....a friend of mine just came back from MMI-Harley school in Arizona. All they run in their bikes is straight 50wt. No issues in the desert....
I agree that Synthetics don't degrade like Dino oil does, because they have a higher flash point and the molecules don't shear as easy.
It's fine. Guys at another forum I go to mix, including straight weights. Most of them have 70K+ on their bikes...
Stick to same-brand oil when you do it.
However, if you mix 50wt with 20w50, why not just run straight 50w in the summer?
Dave
HERD MEMBER #10
"No man's life, liberty, or property are safe while the legislature is in session."-Mark Twain
I'm a big, hairy wrenching machine.....
vB code is On
