Old 11-03-2009, 02:47 PM   #1 (permalink)
Senior Junior Member
spark949's Avatar
Oil identity question.
Hi all...new Super Glide (to me) owner here. I'm from Ct and have had Harleys before, but many years ago. I was riding a (cough, cough) metric for the past couple years, but now I'm back!
I just bought a Super Glide 2002 with 10,400 miles on it and want to change all the oils. I'd like to put synthetic in it but am wondering if there is an issue about changing to synthetic after so many miles. Also, I don't know if there is synthetic in the motor or trans now. Is there a way to tell? Thanks
spark949 is offline   Reply With Quote
Old 11-03-2009, 02:54 PM   #2 (permalink)
Yukity, yuk, yuk.
No issues with changing from Dino to Synthetic or back. I do it every winter/summer.
The only vehicles you need to worry about are pre 1980 vehicles, due to natural rubber seals. Apparently, natural rubber Walruses don't care.
No, there's no way to tell if it's synthetic by just looking. If it were 20*F degrees outside and your bike sat over night in the cold and the next morning the oil was still thin, then you'd be looking at syntetic oil. Anything else would be via lab testing to determine that.
Your next Q was: How much oil does it take? :lol8
A Dyna takes 2.5 qts of motor oil with the filter. Afterwards, start it, run it and recheck it. The oil gets checked ON the kickstand, engine off of course, as the Dyna's oil pan is low and there's no need to stand it upright.
Trans takes 24 ounces. (dipstick, check on stand too)
Primary takes 32-38 depending on who you ask. I run a tad less then a qt, but a full quart is good.
Primary oil should NOT have "Energy Conserving" in the API rating label on the back. Lubrication additives can make the wet clutch slip.
I believe these numbers are good. Anyone else that sees I'm off, please speak up and correct me. I'm not around a manual...............
DISCLAIMER: Any information, advice, or comments I give on this forum should be taken with a grain of salt. Do not try this at home. I am a perfeshunel.
HERD Member #0010
Proud Sponsor of Bung Balm.
Old 11-03-2009, 06:16 PM   #3 (permalink)
Ohutchins's Avatar
Images: 17
could be wrong becuase i dont have my manual with me either but i belive it says to check trans with bike upright and dipstick resting on threads
Theodore Roosevelt
"Treat me good, I'll treat you better. Treat me bad, I'll treat you worse"
Sonny Barger(Freedom: credos from the open road)
Ohutchins is offline   Reply With Quote
Old 11-03-2009, 06:35 PM   #4 (permalink)
Yukity, yuk, yuk.
Yeppers. You're correct.
HERD Member #0010
vB code is On
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum Sportbikes Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums Triumph Forum
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum Triumph 675
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R Can Am Spyder
KTM Forum Yamaha R6 Honda Fury Forums Kawasaki KLR 650 Aprilia Forum
Victory Forums YZF-R6 Forum Honda Goldwing Kawasaki Versys BMW S1000RR Forum
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
