Thanks for the help
Thanks all, actually got ht ebike in 09, and worked up until this year then retired. Now riding all the time. The issue I found out, is operator headspace error. Instead of setting the VOX, I was using the PTT switch for both the intercom and the CB. Not the way to ogo when riding with others. So when my other half and I are riding by ourselves we use the PTT, when we are riding with others we use the VOX for intercom and PTT for CB. I have never had an issue with not being able to hear on the intercom, either above or below 65. Anyway I appreciate the time you all took. I guess if I would have read the instructions I would not have had to ask. I try and do all my own work, and have the HD service manual. I can change all my fluids and plugs and tires without paying 85 dollars an hour!
