Air cleaner removal/clean - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-15-2012, 12:54 PM   #11 (permalink)
Seņor Member
Chief Illiniwek's Avatar
Images: 55
Originally Posted by Big D. View Post
Chief, I have been following your progress so far and have to say that you are doing a great job! I admire the fact that you are not letting minor setbacks deter you. Threads like these are what make this forum so great.
Keep the updates coming!
Thanks for the support, D. I have no choice. Looks like a shop would just eff it up worse. I'll clean up their mess and then just do everything myself going forward. I kind of like evenings in the garage. Beats the hell out of TV.
2011 Road King Classic, Python slip-ons, Stage 1 SE a/c, Power Commander V
Chief Illiniwek is online now   Reply With Quote
Old 11-15-2012, 12:56 PM   #12 (permalink)
Seņor Member
Images: 55
Originally Posted by chasarms View Post
Chief,
When I run across fubar-ed fasteners, my first choice it to try my EZ-outs.
They are basically a set of reverse-threaded, conical doohickeys that work awesome in removing just your sort of problems.
They are quite utilitarian and not too expensive. I highly recommend.
Charles
Is it a drill bit? I think I have one of them thingys. You like that better than creating a flat head slice with a dremel?
My EZ-out looks a little meaty for this little screw.
Old 11-15-2012, 12:58 PM   #13 (permalink)
03 CVO RK
GotGold's Avatar
I'll PM ya the number of Valley for the stuff ya can't handle. Located in Crete or Steger off Rt 1.
"Our lady of blessed acceleration don't fail me now."--- Elwood
GotGold is offline   Reply With Quote
Old 11-15-2012, 01:03 PM   #14 (permalink)
Seņor Member
Images: 55
There's a guy down here I trust. And, so far, I trust the new owner of my dealer. I just hope I won't be needing them much. I'm focussed on taking my time and learning everything I need to know.
Old 11-15-2012, 01:05 PM   #15 (permalink)
Hockey my Life
JPWendtinc's Avatar
Images: 17
If you do not have a Dremmel or a set of ez outs and would have to buy either, I would go with the ez outs. It is a great tool to own and you will use it.
JPWendtinc is offline   Reply With Quote
Old 11-15-2012, 01:17 PM   #16 (permalink)
Seņor Member
Images: 55
Drill it in and then what?
Old 11-15-2012, 01:22 PM   #17 (permalink)
Hockey my Life
JPWendtinc's Avatar
Images: 17
No drill.
The conical ridges are sharp and counter clockwise. You put the appropriate sized ez out into the stripped bolt, tap it with a hammer, put an adjustable wrench on the end and turn lefty loosey.
Old 11-15-2012, 06:13 PM   #18 (permalink)
mgosset1's Avatar
thats why i always keep sharp drill bits and small set of ease-outs on hand...
mgosset1 is offline   Reply With Quote
Old 11-15-2012, 10:44 PM   #19 (permalink)
Seņor Member
Images: 55
Dremel slot was clean. Practiced on another bolt head first. Still wouldn't budge. Ended up cutting the head off with Dremel and sliding filter off over the stem.
Filter was dented under two of the three screws. Whoever mounted that sucker drove it home. What a Richard.
I'm leaving for A conference tomorrow and then Mexico with the fam Saturday. I'll be shopping for a new filter and new hardware when I return.
BTW, another clutch adjustment and my lever pulls smooth. The downside is I adjusted the thing four times. The upside is I now have a full understanding and a bit if a "touch" for doing clutch adjustments. Never too old to keep learning.
Old 11-15-2012, 11:08 PM   #20 (permalink)
butch61's Avatar
Images: 5
i'll be waiting for the " i split my cases today" thread keep up the good work
butch61 is offline   Reply With Quote
