If you're referring to the jam nut for the clutch basket adjusting Allen bolt ....it just needs to be tightened. Its almost impossible to torque the nut as you need to hold the Allen in the center. 120 inch lbs is 10 ft lbs. There's no given range cause you're not going to successfully torque it with a torque wrench and keep your clutch adjustment. Never ever saw one come loose.
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
