final0 drive chain tension,,,, - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-20-2012, 10:22 PM   #1 (permalink)
The book calls for only a 1/2 inch play,,,,, damn that feels tight to me now that I adjusted it,,,,, if you had the choice, too loose is better than to tight yeah?
grouser is offline   Reply With Quote
Old 11-21-2012, 05:44 AM   #2 (permalink)
SCHMIDTYS's Avatar
You need to check the adjustment at different locations, like every 12 inches then make the adjustment at the tightest spot and it'll be good.
Too tight will wear the sprockets out prematurally ! Check your sprockets for cupped teeth.
Old 11-21-2012, 10:07 AM   #3 (permalink)
did not think of that,,,, may make a difference,,, thanks
