Speedometer only goes to 25mph - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 11-26-2012, 12:18 PM   #1 (permalink)
AlTheKiller's Avatar
This morning on the way into work I noticed the speedometer wouldn't go above 25mph. Everything lights up and it shows the trip and mileage correctly though.
Where should I start looking for the problem? Anyone have this problem before?
It's a 1999 sportster 1200 custom but the tank I think is after market with the speedo mounted into it.
Thanks for any help.
AlTheKiller is offline   Reply With Quote
Old 11-26-2012, 12:22 PM   #2 (permalink)
Have you checked the speed sensor?
Old 11-26-2012, 12:28 PM   #3 (permalink)
No sir. I haven't checked a thing since I've been at work. Would that be the best place to start?
Old 11-27-2012, 07:09 AM   #4 (permalink)
SCHMIDTYS's Avatar
Agreed about the speed sensor. It's located behind and below the starter on top of the trans case. One wire to it and one Allen bolt holding it in. Remove the sensor and clean the debris off the magnet. The debris interferes with the speed signal.
Old 11-27-2012, 10:05 AM   #5 (permalink)
What he said. Cleaning it worked for me a couple of times, then it needed replaced.
fxrglide91 is offline   Reply With Quote
Old 11-27-2012, 10:27 PM   #6 (permalink)
thanks everyone. I still havent had a chance to pull it yet. Its been working again but tomorrow I should have some free time to get it out and cleaned up.
Old 11-28-2012, 07:39 AM   #7 (permalink)
Proud South African
If it was the speed sensor then your mileage would also be incorrect. Check your trip distance after your trip, if it seems accurate then the problem's with the speedometer itself.
OomD is offline   Reply With Quote
Old 12-19-2012, 09:33 PM   #8 (permalink)
GlideWide's Avatar
Give it more gas!!!
GlideWide is offline   Reply With Quote
Old 12-19-2012, 10:39 PM   #9 (permalink)
RicManSr's Avatar
Originally Posted by GlideWide View Post
Give it more gas!!!
Or shift to second gear!!!
RicManSr is offline   Reply With Quote
Old 12-20-2012, 11:31 AM   #10 (permalink)
webco2 is offline   Reply With Quote
