Screamin' Eagle Street Performance Tuner? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 4 (permalink) Old 10-22-2010, 09:33 PM Thread Starter
Just got a 2008 CVO Springer. Bike was a repo with 9300 miles. Baffles have been removed so I was going to go with Vance & Hines Big Radius 2 into 1, I like the looks and have friends who have them that like their performance. My dealer says if I get these pipes I would need to get the Screamin' Eagle Street Performance Tuner and in addition this would require 4 hours dyno time at $320. Harley's own instructions state: quoting(Once installed, the kit will allow the dealer to upload the latest ECM calibrations for your bike's legal state-of-tune for only a minor labor fee.) Is an aftermarket tuner required? Bike is out of warranty. Just do not want to damage the engine. Can the ECM on the bike just have new parameters downloaded? Was told by dealer also that once the baffles are removed my only option is a new set of pipes? Anybody have any input.
Thanks.
BigBouchet is offline
post #2 of 4 (permalink) Old 01-26-2011, 01:24 PM
2010hdultra's Avatar
EFI tuners
I have a 2010 ultra classic and have put on the rhinehart slip ons and soon to install a se stage 1 intake kit. I have done research and to the best of what i am understanding you have 3 options to get your bike tuned.
1. you can have the dealer reflash the ecm with a stage 1 tune that is specifally designed by HD to match the bike and their SE parts, but most dealers say that this tune will work for most mild mods since none of them really differ much in the performance areas, mostly cosmetic and sound differences. all of them increase air in and exhaust out. therefore increasing power and requiring a non-stock ecm tune, I beleive the dealers call this a ecm download and should run ya about $150-180 at the dealer. good if your done with mods and want a mild setup.
2. you can buy the SE street performance tuner which is about $320 and this will allow you to take it to HD dealer and they can download a HD map to your ecm and only charge about $50 bucks. there are some larger deales that actually have dynos that will sale you a map for this unit that is more specific to your setup for about $50 also. this option would be good if you plan to make small changes over the life of the bike. but would require hd dealer to download a new map after each change.
3. the most costly up front, is the SE pro race tuner and software. this would allow you to not only download stock hd maps for your setup, but also allow you to use the autotune feature to get a closer tune to your setup, or take it to a dyno shopp and have them custom tune it to your preferences, such as full race tune giving the best power but least efuel econ and very high heat. etc.
i am still trying to decide which way i should go. i want a good tune to cool the engine down and accomidate the intake and pipes, but want the functionality for the future if i decide to go big bore or cams. etc. just depends on what you want and how much you wanna spend. if i am incorrect in any of this please let me know as it would help my understanding alot.
2010hdultra is offline
post #3 of 4 (permalink) Old 03-04-2011, 09:32 AM
kickstand grinder
59panhead's Avatar
fuel pak V+H
Put a fuel pak on a new 113 w stage one and bartels pipes, straights- Runs like a new bike. Faster, run cooler, no pop on decel, bitch runs. I think he said it was 400 through J+P cycle. No prob, took 45 min to install and program- only had to set it once.
59panhead is offline
post #4 of 4 (permalink) Old 03-04-2011, 11:22 AM
mrmetal's Avatar
There are several other options. Here are two more. Revolution performance Reprograms your original ECM. And then there's the thunder Max which I have on my bike. You can adjust the thunder Max for any modification without putting it on the Dino.
Performance Parts for Harley-Davidson and Buell ? Revolution Performance
Electronic Fuel Injection (EFI) and Performance Parts for Harley Davidson and VTwin Motorcycles
mrmetal is offline
  LinkBacks (?)
LinkBack to this Thread: http://www.Harley-Davidsonforums.com/forums/harley-davidson-forum-site-issue-forum/24816-screamin-eagle-street-performance-tuner.html
Posted By For Type Date
Harley Davidson Forums: Harley Davidson Motorcycle Forum This thread Refback 10-23-2010 06:55 AM
