Mobile 1 in All Three Holes - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 12 (permalink) Old 07-28-2013, 07:00 PM Thread Starter
Toolman44092
Toolman44092's Avatar
I've been reading as many threads as I can and following links. Mobil 1 says their V-twin 20-50 can be used in all three holes with no issues. Someone on here said Harley says you can do the same with Syn 3 (makes sense if you can with Mobil 1). It sounds like the issue is with clutch feel.
Can anyone who has actually done this chime in? What's the negative? Thanks.
2012 Street Glide owner
Toolman44092 is offline
post #2 of 12 (permalink) Old 07-28-2013, 07:28 PM
Poser Member # 99
big john@dog's Avatar
Images: 5
look at the bar going across the top you'll see it say Forum . Click on that and then scroll down to where it says Oils and filters.
It's every thing you ever want to know about oils and Filters and the do's and don't .
A lot of guys use it in all 3 holes Some prefer other oils. It's just a preference.
Enjoy and Good luck with what ever you choose
big john@dog is offline
post #3 of 12 (permalink) Old 07-28-2013, 07:34 PM
On Probation
HDSickness's Avatar
Fine for motor and primary, but I would not use it in the tranny, use a good gear lube like.......Redline.
Confuse a liberal.....Use facts and logic.
_____________________________________________
2010 Ultra Limited FLHTK
SE Ventilator
SE Super Tuner
Jackpot Stainless Header
Rinehart 4" Muffs
I'll try to be nicer........If you try to be smarter.
HDSickness is online now
post #4 of 12 (permalink) Old 07-29-2013, 06:39 PM Thread Starter
Toolman44092
Why?
post #5 of 12 (permalink) Old 07-29-2013, 07:14 PM
On Probation
HDSickness's Avatar
Originally Posted by Toolman44092 View Post
Why?
I think a gear lube is better for a gear box.
My experience is better, smoother operation.
I believe in using a product that is specific to each hole.
SE Ventilator
SE Super Tuner
Rinehart 4" Muffs
post #6 of 12 (permalink) Old 07-29-2013, 07:23 PM
JPR
Glad to be anywhere
JPR's Avatar
Images: 15
I use the Redline shock proof in my tranny. Tranny oil takes a different type of beating than engine oil. It stands up better to the shearing forces in the transmission.
The Syn 3 or Mobil 1 stands up to the high heat of the engine and is primarily designed for engines.
The shock proof trany oil from Redline comes highly rated throughout Harleydom. I used to own a Transmission shop.
I use Harley's +P in the clutch. It's designed for the clutch which has different needs and operating temps from the engine and tranny.
BUT YOU CAN USE MOBIL 1 for V Twins 20-50 in all 3 holes. Some engine oils (but not syn 3 or Mobil 1) have additives that are not good for the clutch.
Redline is more expensive than Mobil or Syn but after spending close to 20 g's on your bike why skimp on a quart of oil?
After reading the info available here on the forum and discussing it with the lead mechanic at my dealer, I decided to use what I described above. And I'm still using Harley dino 20-50 in the engine but I'm likely to switch to Mobil 1 V-Twin 20-50 for the engine.
Read up on the subject matter here in this forum.
That was me 40 years ago
My how times have changed
I think therefore I am (Cogito Ergo Sum) Descartes
I ride therefore I am (Veho Ergo Sum) JPR
65 Italian scooter
66 305 Rice burner; NO PROBLEMS
67 650 English Bike; MAJOR PROBLEMS
1968/XLCH - lots of mods; loved it for 11 years; NO MECHANICAL PROBLEMS
2012 Heritage 103 Rush 2.0 pipes MAMBO #5
bought all brand new except scooter
There's a picture of the sportster after all the mods in my images file.
JPR is online now
post #7 of 12 (permalink) Old 07-30-2013, 06:56 AM Thread Starter
Toolman44092
I read through quite a bit of the posts on here. Most of what I saw regarding using the same oil in all three holes was from people who thought you shouldn't for various reasons but never mentioned trying it themselves. I believe that Mobil 1 is such a quality oil that nothing will get hurt, but I don't know this for sure. Some people mentioned the clutch feel will change, and I'd like to know more about that.
I was just wondering what the positives or negatives were from people who have done it or still do it. Thanks for the input so far.
post #8 of 12 (permalink) Old 07-30-2013, 12:59 PM
TheJayBird's Avatar
I too am interested in the 'different feel' of clutch. Personally I run either Harley synthetics or Amsoil synthetics. You woulnt use motor oil in the tranny of ur car, so why do it with bike
-JayBird
Thank you for everything...
Now Ride Free Rick n I'll catch ya on the fipside
TheJayBird is offline
post #9 of 12 (permalink) Old 07-30-2013, 04:11 PM
ciscokid's Avatar
i just started using moble one in the engine (they say it drops temps) i have yet to see the temp drop . it still runs 200 225 all the friggin time. going to try the it in clutch and trans soon will post how that goes when i do.
CISCO KID
ciscokid is offline
post #10 of 12 (permalink) Old 07-30-2013, 06:25 PM
JPR
Glad to be anywhere
JPR's Avatar
Images: 15
Thanks for that report Cisco. I've been agonizing over switching to synthetic to the engine (still running dino in a low mileage bike).
No one has ever reported a normal engine failing because they used dino oil of the proper grade. The lead mechanic at the dealership has recommended staying with the stock oil. Milwaukee still ships its new bikes with dino 20-50.
And everyone who has switched to synthetic says the upper end is noisier. (which I don't want)
65 Italian scooter
JPR is online now
