Oil dripping from Air cleaner - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 24 (permalink) Old 05-31-2010, 08:37 PM Thread Starter
Leigh's Avatar
Images: 3
Ok, I am finding oil under the air cleaner on the engine. Not alot, notice it after a long ride. I have a 2008 Ultra Classic. I am thinking maybe some engine blow off of excessive oil. Any suggestions. I have been checking the oil level and all is normal. Thanks.
2008 Ultra Classic
Leigh is offline
post #2 of 24 (permalink) Old 05-31-2010, 09:09 PM
its blow-by from the crankcase! as the motor runs the crankcase build pressure and there are breathers that are connected to the crankcase that send the air with a little oil mixed in back into the air cleaner to reburn it! sometimes it will collect in the air cleaner ! So clean it and check it now and then! dont think there is anything to worry about!
Panhead1959 is offline
post #3 of 24 (permalink) Old 05-31-2010, 09:12 PM
Normal
JimmyG is offline
post #4 of 24 (permalink) Old 05-31-2010, 10:54 PM
XD45lover's Avatar
i have an 08 EGUC and if i put in more than 3.5 Qts of oil, i get it all over my air cleaner too. make sure cold, the oil is between needs and full and you will be fine. nothing to worry about. if you want a scooter that doesn't leak oil i heard those Ricers do nice, but you wouldn't catch me dead on one... lol
XD45lover is offline
post #5 of 24 (permalink) Old 06-01-2010, 04:51 AM
Most Wanted
confederate's Avatar
Images: 17
I've had that happen a few times as well. I lowered my oil level to 1/4 above the add mark. Hasn't happened since.
FXDC
SEPST*HP 75.81*TQ 87.61*Stage 1*Rinehart Exhaust*Arlen Ness Big Sucker
K&N Hi Flow Filter*HD Retro Air Cleaner Cover
HD 4inch risers*J&P Cycles Highway Pegs
"I'd boil her panties and make soup"
confederate is offline
post #6 of 24 (permalink) Old 06-01-2010, 05:56 AM
Nomad
It's like Panhead said. in the picture you will see the breather tubes. They are connected to your rockerboxes and when the rockerbox vents the gasses vented are burned in the engine... or at least that is how I understand it.
TxFLSTC is offline
post #7 of 24 (permalink) Old 06-01-2010, 09:37 AM
The Northern Redneck
Blackdog 15's Avatar
Drop your oil level a tad...should stop....
If Ya Ain't the Lead Dog, The View NEVER Changes
You can Sleep when ur Dead...
Baggers RULE !!!
http://www.youtube.com/watch?v=bTrb4YGkSOU
HERD Member # 000015
Blackdog 15 is offline
post #8 of 24 (permalink) Old 06-01-2010, 12:42 PM
Dropping the oil level helps, also running straight weight oil, and running dyno helps also. On quick revving larger dissplacement builds we also take the vents to atmosphere.
Kingofcubes is offline
post #9 of 24 (permalink) Old 06-03-2010, 12:04 AM
Angry misfire
HAVE A 1996 SOFTAIL. SOMETIMES IT MISFIRE ON LOW SPEED OR HIGHSPEED.
harley_chep is offline
post #10 of 24 (permalink) Old 06-03-2010, 05:45 AM
What also can be done, is to drill the rocker support drain holes to .125".
That allows the separated oil to drain away much quicker.
Scott
"....3 dueces and a 4 speed..........and a 389"..........
Goodson H-D Cylinder Head Tooling Manufacturer
Celebrating 30 Years of HD Engine Building
Hillsidecycleco is offline
