Tranny and Primary Oils - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 12 (permalink) Old 05-23-2011, 09:51 AM Thread Starter
Just wondering what other oil could be used instead of the Harley Formula+ in the tranny and primary. I want something with the equivalent standards or better ofcourse. Looking for a product I could find closer to home instead of running to a Harley store 50 miles away. I do see some in the local parts stores but I want to know more about it before I start using it. Any knowledge of this would be appreciated.
Gliderider is online now
post #2 of 12 (permalink) Old 05-23-2011, 09:59 AM
Badinfluence's Avatar
Some use transmission fluid in the primary. Some use gear lube in transmission. Go to the oil section and read posts till you decide what you want to use.
Badinfluence is offline
post #3 of 12 (permalink) Old 05-23-2011, 10:06 AM Thread Starter
Sorry, kind of new to the site and saw the oil section after i posted. Thanks!
post #4 of 12 (permalink) Old 05-23-2011, 10:23 AM
There is a search function at the top of the page also.
post #5 of 12 (permalink) Old 05-23-2011, 12:02 PM
A non-energy converving 20w50 oil is fine. Synthetic or dino. If running trans fluid, Dextron-III is best. Don't recommend using Type-F, as it lacks lubrication qualities and you have bearings in that primary. I've run most if not all of them, and just use 20w50 motor oil or Dextron-III.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #6 of 12 (permalink) Old 05-23-2011, 03:11 PM
bgdv1's Avatar
Images: 3
im running castrol vtwin 20w-50 synthetic in the engine & primary and royal purple 75-90 synthetic in the tranny. any of these can be bought at your local auto parts store. (autozone,pepboys,advanced etc.)
2011 black denim SG,SE 103 w/255 cams, SE ventilator, V&H Power duals,4" Rineharts, Dynojet PowerVision,
10" LA Chopper Twin Peaks bagger bars, lots of xtra chrome,ipod,garmin 255W, 19"/18" contrast chrome agitators
bgdv1 is offline
post #7 of 12 (permalink) Old 05-23-2011, 03:18 PM
when did it start 4u
Jacket4256's Avatar
belray in tranny and primary here
2004 Sportster
2012 HD Road Glide Ultra
2006 GTO with idle problem
2011 Subaru OB (DD)
A great man once said
Jacket4256 is offline
post #8 of 12 (permalink) Old 05-26-2011, 10:22 PM
Mobil 1 v twin 20w50 in all 3 holes.
yj94 is offline
post #9 of 12 (permalink) Old 06-05-2011, 10:25 PM
I've used Amsoil in bikes since the late 60's and have had good mresults. You can buy amsoil at dealers but costs more.I joined amsoil as a member and order on line and gets ups to me in a couple of days and less expensive than at dealer cost. Hope this helps. vrod.
vrod is offline
post #10 of 12 (permalink) Old 06-13-2011, 11:39 PM
Well doin MY first oil change on this bike since I bought it. its a 08 road king with almost 21K miles now..
I finally decided with
AMSOIL SYN 20W50 for the Engine
Redline Shockproof Heavy for Tranny
AMSOIL 75/90 for Primary
I've heard great this about this RedLine shockproof, so I thought'd give it a try.
I'm taking a trip up to Indiana from Texas starting July 1st, So thought I'd service her a bit for a 1200 ride.
HoosierBoy is offline
