1979 SPORTSTER oil tank, hot and cold while running - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 8 (permalink) Old 11-17-2016, 07:45 PM Thread Starter
jimlisa's Avatar
Hi, On my 1979 Sportster I bought from my bud , I started checking all out and I found that when the engine is at normal operation temperature the left (drivers) side of the oil tank is HOT, on the fill side, right side it is absolutely cool. What is up with that. My vent line goes to the right side top near the filler and the return is going to the top left forward of tank. The hoses are different sizes which makes me think this is normal, but why should it be blazing on one side and very cool on the other. It looks to me as though the feed is taking in the return as soon as it re enters the tank, not getting a chance to circulate properly with the rest of the oil in the tank. It makes no sense to me. Touching the right side of tank you wouldn't think the engine was even run?
Thanks all.
jimlisa is offline
post #2 of 8 (permalink) Old 11-18-2016, 06:45 AM
Check that the hoses are connected to the proper points on the tank. Maybe someone re-routed the hoses incorrectly.
bobf is online now
post #3 of 8 (permalink) Old 11-18-2016, 06:49 AM
I think the feed and return lines are both near the bottom of tank, and the vent is at the top. Check that someone hasn't swapped something.
Have a look at the parts breakdown for diagrams.
bobf is online now
post #4 of 8 (permalink) Old 11-18-2016, 12:50 PM
candyman1340's Avatar
candyman1340 is online now
post #5 of 8 (permalink) Old 12-16-2016, 10:43 PM Thread Starter
jimlisa's Avatar
Bobf, I have it exactly as you outlined it. I have trace all the hoses to make sure the feed is clear, the pump is gushing w/o the pressure sensor sensor attached and the vent attached to the top. When it runs you can pull the vent, suck on it anything bur I did notice a pulse which I suspect is from crankcase pressure? I'm gonna read a few recommended url's above but it just seems assonine that the oil doesnt circulate thru out the tank enough, or at all while. The return is working. Now heres what blows my mind is that the left side of the tank is very hot and the right side is as cool as when started. It's like someone is playing a joke on me.! lol
Thanks for the input everyone
jimlisa is offline
post #6 of 8 (permalink) Old 12-17-2016, 08:55 AM
OK, having had a better look at the tank, both the feed and return are on the same side, so unless you go ride it and "stir" up the tank that side will be much hotter than the other side. If you ride it around and "stir" up the oil, the tank will be much more even in temperature.
bobf is online now
post #7 of 8 (permalink) Old 12-22-2016, 10:30 AM Thread Starter
jimlisa's Avatar
Bobf, .and all. Ya when the weather breaks,....next year I'll take her out for a spin. It's gotta be something like that. I was gonna look in the tank with a scope and see if all is well, but what could that show me. It's sending and returning. It's probably normal for the bike.......you're probably right. Thanks
jimlisa is offline
post #8 of 8 (permalink) Old 12-23-2016, 12:15 PM Thread Starter
jimlisa's Avatar
Maybe I won't wait till nest year. oh ya, New Years coming so it will be next year! Thats what I meant. lol .
Hey Merry Christmas and a Happy New Year to all!
jimlisa is offline
