Mixing HD+ and Mobil 1 20/50...ok? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 10 (permalink) Old 02-26-2012, 05:45 PM Thread Starter
Retired firefighter
KMAN96ULTRA's Avatar
Images: 38
i an changing all the oils today..and ran short of hd+ for the primary,
can i mix mb1 20/50 or is that not a good thing?
Still UP-RITE....and PUMPING AIR
A old scout once said...Lead...Follow...or get the hell
out of the WAY
KMAN96ULTRA is offline
post #2 of 10 (permalink) Old 02-26-2012, 06:16 PM
Mixing oils isn't recommended, because of different lubricant packages.
In all honesty.... I've done it, used similar oils, and never had an issue.
Mobile-1 in the primary will work, as long as the back of the bottle doesn't have "Energy Conserving" in the API rating seal.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 10 (permalink) Old 02-26-2012, 06:29 PM
Dave, wouldn't you be mixing oils, to a little degree, if you just changed from dino to synth? Unless you did a complete system flush . . . .
Tucson_Tim is offline
post #4 of 10 (permalink) Old 02-26-2012, 06:55 PM
Yes.... that's my point. It's almost unavoidable in some cases.
I could see if you were using super-flow-magic oil, and went to water-base-lubri-juice, but that just isn't gonna happen.
Oils for certain applications are all pretty much the same, if in the same class of motor oils or specific lubricants.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #5 of 10 (permalink) Old 02-26-2012, 09:36 PM Thread Starter
Retired firefighter
Images: 38
how about mb1 75/140 would that be better?
out of the WAY
post #6 of 10 (permalink) Old 02-26-2012, 09:49 PM
That would be good in the transmission. But not in the engine or primary case. Lot of people put the same oil in all three holes but I think it's better to use tranny oil in the tranny.
post #7 of 10 (permalink) Old 02-26-2012, 10:02 PM Thread Starter
Retired firefighter
Images: 38
thanks!!!!
out of the WAY
post #8 of 10 (permalink) Old 02-26-2012, 10:32 PM
Addicted Since 2010
XL1200R's Avatar
Images: 38
Agreed
No reason to not use the correct lube for the job.
Cheap insurance
Sent from my DROIDX using Motorcycle.com App
"Mr. Lahey is this you talking or the liquor?"
"Randy...(takes a swig)...I am the Liquor!!!"
XL1200R is offline
post #9 of 10 (permalink) Old 03-05-2012, 10:33 PM
Ride Hard
DSMITH's Avatar
I also use tranny oil the trans. I do like Amsiol in the primary. Feels right for me.
DSMITH is offline
post #10 of 10 (permalink) Old 03-06-2012, 01:15 AM
أنا كافر
Kainam's Avatar
Images: 150
I use Dexron III ATF in the primary.
Dexron III ATF.
Along with auto transmissions, Dexron III is also used in chain driven 4x4 transfer cases (NP207, NP208 etc)...
After all, what is in an automatic transmission? Clutches, bearings etc... ATF is also used in chain driven transfer cases (NP 207/NP 208) that have.... chains.
Sounds like a HD primary to me.
Here's what Barnett has to say about primary oil
As far as what oils to use, we generally suggest following the manufacturer's recommendations. Use only quality motorcycle specific oils. The main purpose of oils in a "wet" clutch application (as far as the clutch pack itself is concerned) is to act as a coolant. Oil flowing through the clutch plates help to keep the plates cooler, resulting in smoother clutch action and longer life. Using too heavy viscosity can cause plates to stick when cold. All Barnett wet clutches are designed to be used with synthetic or petroleum based oils.
NOTE: We do not recommend using the Harley Davidson Formula Plus oil with our clutches. Remember, the single best insurance you can have for your clutch and bike is to keep clean, good quality oil in it!
Barnett Performance Products
I use Mobil 1 75w-90 in my transmission.
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
Kainam is online now
