Leaking oil threw breather - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 2Likes
post #1 of 55 (permalink) Old 03-31-2009, 04:04 PM Thread Starter
My Bike is leaking alot of oil threw the breather. What could be the cause for that and how can I fix it?
Anthonyamastr52 is offline
post #2 of 55 (permalink) Old 03-31-2009, 05:39 PM
well, what motor, year and model of bike?
evo motors vent the case through the breather. If you pullout your air filter, you should have an oily film on the mounting plate and around the rim of the filter.
ironhead bobber is offline
post #3 of 55 (permalink) Old 03-31-2009, 09:40 PM Thread Starter
Its an evo engine. The year im not sure of its a chopper I bought it built already so not sure of the year all i know itrs from the 90's
post #4 of 55 (permalink) Old 03-31-2009, 10:54 PM
try cleaning or replacing your air filter, may just be clogged and/or wore out. otherwise, may be a problem with the oil system...old ironhead motors were notorius for all of the oil in the bag draining down into the crankcase if you left them sitting for too long, especially if you had too much oil on the bag. I understand you have an evo rather than an ironhead, but, could have a problem still.
post #5 of 55 (permalink) Old 04-01-2009, 06:31 AM
Depending on how/if the engine was rebuilt, there's ALOT of reasons that could happen.
Blocked return holes.
Partially restricted pushrod tubes.
Improper oil pump timing.
Improper head venting.
Excessive blow-by due to worn rings.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #6 of 55 (permalink) Old 04-01-2009, 07:22 AM
أنا كافر
Kainam's Avatar
Images: 150
Also, one other thing that can cause it, if none of the above fixes your problem.
Ive had the stock plastic crankcase breather valve shell out and cause excessive oil blowby thru the breather.
S&S makes a steel replacement one.
http://www.sscycle.com/catalog/50/ca...iew.php?id=254
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
Kainam is online now
post #7 of 55 (permalink) Old 04-01-2009, 08:12 PM
2007 Ultra Classic
Dinero No Mas's Avatar
Bad umbrella valve issue or valfes replaced with the incorrect sealing space for the umbrella.
Dinero No Mas is offline
post #8 of 55 (permalink) Old 05-10-2009, 02:42 PM
Oil Leaking through air filter
Hi I have a 2003 Ultra Classic. I notice when I am running 70mph on the highway for awhile, oil will blow out of my air filter. Last week, I had my pump adjusted, but the oil still blows out at higher speeds. This didn't start until I had my Cam chain tensioner adjusted and they put in some adjustable push rods so they would not have to go into the top end. Ever since then I'm getting blow-back. This is a twin-cam engine. Does anyone know what could be happening? Or what can I look at?
bacslc is offline
post #9 of 55 (permalink) Old 05-31-2009, 10:09 PM
I have read all of these but I have one question,
I've been told from my local Harley Dealer Mechs. that my after market pipes are causing my blow back into my air filter , and the remedy is to replace the jets with bigger ones.
Now with that said how many of you have after market pipes? and is this a true statement?
basscatcher is offline
post #10 of 55 (permalink) Old 05-31-2009, 11:39 PM
Rock Slide's Avatar
I have a hard time believing that one...
If its a mid 90's Evo, some oil will drip out the air cleaner due to the vent dumping in there. If all the points noted above are good (rings-breather valve-etc), you'll have to live with it or reroute your vent tube to under the bike and put a filter on the end of it. You may still get drips but it won't be on the cases...
FrankenTrike likes this.
Rock Slide is offline
