Oil Change Doofvcky - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 10Likes
  • 3 Post By Kainam
  • 1 Post By Badassbrutus
  • 1 Post By gruss
  • 1 Post By HandOverFist
post #1 of 8 (permalink) Old 05-14-2009, 01:50 PM Thread Starter
أنا كافر
Kainam's Avatar
Images: 150
Oil Change Doofvcky
Just cut the bottom off of a plastic plastic pop bottle.
Then remove a section down the side (sorta like a canoe cut in half) so it can slip under the filter bottom.
Insert the bottom of the 2-liter bottle under the filter coming in from the left side of the bike instead of from the front as with the card board method. Then when you loosen the filter the oil will run down collecting in the neck of the bottle. Remember to leave lid of the bottle attached.
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
Kainam is online now
post #2 of 8 (permalink) Old 07-21-2009, 11:02 AM
If you dont drink soda you can use aluminium foil and shape it any way ya want.
Dyna FXD likes this.
Badassbrutus is offline
post #3 of 8 (permalink) Old 07-21-2009, 02:58 PM
"Nervous Tick"
gruss's Avatar
Images: 29
i use a plastic freezer bag. break the filter loose, place the bag over the filter and fit it around the casting of the engine block, spin the filter inside the bag, and presto-filter and oil are in the bag!
have done this without spilling a single drop of oil onto the engine.
g
Kainam likes this.
I didnt buy a Sportster because I wanted a Harley,
I bought a Harley because I wanted a "Sportster"....
gruss is offline
post #4 of 8 (permalink) Old 10-29-2009, 02:22 PM
tloftus3's Avatar
I use a cut anti-freeze bottle. Works great!!
tloftus3 is offline
post #5 of 8 (permalink) Old 01-07-2010, 11:19 AM
Ever cut your hand fooling with one of those cut plastic bottle "Do-Hickies"? They will cut your hand better than some pocket knives I have owned! BE CAREFUL!!
Tweedy is offline
post #6 of 8 (permalink) Old 03-22-2012, 01:05 AM
Leave the cap on your bottle of choice and the oil is self contained...no need to aim for a drip pan.
big john@dog likes this.
HandOverFist is offline
post #7 of 8 (permalink) Old 06-06-2012, 04:02 PM
Lone Wolf
I just let it run down the engine, then spray starting fluid on it and it runs right off. Drys in less than a minute.
Breeze13 is offline
post #8 of 8 (permalink) Old 01-04-2017, 06:44 PM
Ironman's Avatar
Filter change trick
Anyone else make your own oil filter drain funnel? Here's mine
ID:	550482   Click image for larger version
Ironman is offline
Closed Thread
