» Site Navigation |
» » » » Motorcycle Forums
» Links |
03-26-2009, 03:07 PM
#1 (permalink)
Replacement Bolts for HD
Hello everybody! I am a new owner of a 2008 FXSTC. My wife has a 2009 Sportster XL883L. We are brand new to the biker scene and to this forum.
So far, all I've done to our bikes is add a windshield, engine guard, saddlebags, and a clutch cover. I keep running into the same problem with all the torx drive bolts: they strip out very easily. I plan to do much of the routine mnx on the bikes myself as I am accustomed to doing that for our cars, but with this torx drive problem I am not looking forward to the hassle. I think it would be nice to have some boxes of spare bolts around, but I have had no luck at all in determining who the supplier(s) are for HD. I'd rather not have to go to the dealer for every nut and bolt.
Any suggestions?
Thanks!
03-26-2009, 03:28 PM
#2 (permalink)
Boooya!!!
first thing is to go to the new forum and intro yourself, then proceed to your local snap on tools, craftsman or matco tools dealer and get some high quality torx drivers. i prefer the hardened steel ones that fir onto a 3/8 or 1/4 in drive socket. the cheaply made ones do not fit right and will cause more problems as you have already experienced. The proper fitting torx should be very snug with no play or wiggle room. also should fit all the way into the bolt head not just ride on the top half. good luck.
03-26-2009, 03:54 PM
#3 (permalink)
I had not considered the possibility that my drivers were the problem. They aren't Craftsman, but I'm about to remedy that situation. Do you really think that's it? That would be great! Thanks for the suggestion!
03-26-2009, 03:55 PM
#4 (permalink)
Mentally unstable.
Ditto. Quality is important with torx bits and allens. If dealers used cheap tools, your bike would look like a$$ after they worked on it. Not to mention the quality of the steel isn't what it used to be, regarding the bolts.....
You can either buy a decent set, or figure out what you need, and just go get the sizes you use.....
HERD meber #10
03-26-2009, 05:27 PM
#5 (permalink)
ΜΟλΩΝ λΑβέ
Along with the tool advice listed above, Ace Hardware and Truevalue usually have a good supply of nuts and bolts.... chrome, stainless, grade 8 etc....
Originally Posted by Representative Suzanna Gratia Hupp
"How a politician stands on the Second Amendment tells you how he or she views you as an individual... as a trustworthy and productive citizen, or as part of an unruly crowd that needs to be lorded over, controlled, supervised, and taken care of."
Originally Posted by Thomas Jefferson
"Tyranny is defined as that which is legal for the government but illegal for the citizenry."
'05 Carbed Night Train
111 rwhp, 112 rwtq
03-26-2009, 05:35 PM
#6 (permalink)
when did it start 4u
I also found those lil buggers (torx) from autozone have held up pretty well I needed one a while back and stop by and it turned out to be well made and pretty dang strong, just a thought if your like me and flat broke all the time
1988 FLHS with HACK
2004 Sportster
2006 GTO with idle problem
2008 WRX (DD)
The HERD 00046
A great man once said
03-27-2009, 08:39 AM
#7 (permalink)
Thanks to ALL who posted advice. I went out and followed your advice and bought a set of Craftsman torx and hex sockets from Sears yesterday. Went straight home and they worked MUCH better. The only problem I had was with a couple bolts that I had damaged using the crap tools. Not sure where I got them, but they were the little bits you stick in a screwdriver. I'll also check out Ace Hardware or Truevalue the next time I pass one for a few replacement bolts. Anyway, I feel much better now. Thanks again to all!
03-27-2009, 08:44 AM
#8 (permalink)
ΜΟλΩΝ λΑβέ
Hey, anything to give someone an excuse to buy more tools!
111 rwhp, 112 rwtq
03-27-2009, 09:50 AM
#9 (permalink)
Can you tell I was really tore up about having to go back to Sears for more Craftsman?? Aww, shucks.....
03-27-2009, 02:57 PM
#10 (permalink)
Parka is off
I just picked up some craftsman torx and they aren't snug, is Harley using metric or in.?
| Thread Tools |
| Display Modes |
Linear Mode
