Originally Posted by Leigh
Has anyone used a good camera mount on there ride? I am in the market for a motorcycle camera mount, either mounting on the handle bars or securing on the faring?
Which ones not to use?
Thanks in advance.
Leigh... You have several options.
For a bar mount check out the options here...
http://www.cyclegadgets.com/Products/?cat=MOUNT If go this route make sure you get a mounting arm long enough for a mounted camera to appear over your fairing top.
The GoPro camera is offering a lot of appeal to many. For less than $200 one gets a cam and all kinds of mounting options in the kit, including a stable suction mount for a fairing...
http://www.goprocamera.com/index.php?area=2&productid=5
You don't mention if you want to use an existing camera. If you go the fairing mount option, the cam needs to be very light.
Then there are helmet cam options. HTH.
