» Site Navigation |
» » » » Motorcycle Forums
» Links |
09-10-2009, 04:38 PM
#1 (permalink)
My Dixie Wrecked
Mapping
Getting ready to slap some V&H's on, and I was told by someone that I could remapp with a download from my laptop...Where would I get an adapter for my computer to do this...Has anyone tried this before?
09-13-2009, 03:39 PM
#2 (permalink)
Dr. D
where in louisianna do you live, i am in marrero
To remap, you have to buy the screaming eagle super pro tuner. cables, and cd's If you are in new orleans, they weill tell you that you cant buy the cables and cd's But surdyke harley on the web will sell them to you at a discount..... I just bought a set from them.
I have a 96 and just put the v&h big radius pipes, and the screaming eagle breather on and remapped, it really made the bike come alive. good luck.
Doc
09-14-2009, 05:13 PM
#3 (permalink)
My Dixie Wrecked
Thanks doc...when you say cables, does that include the adapter to run from the laptop to the bike? I'm not too computer savvy....
slidell
"A government big enough to give you everything you want, is big enough to take away everything you have"
Thomas Jefferson
John 11:16 Therefore Thomas, who is called Didymuss, said to his fellow disciples, "Let us also go, so that we may die with Him."
Herd Member 50
09-15-2009, 09:09 AM
#4 (permalink)
Dr. D
The super pro tuner is just a communication module, kinda like a modem. Your dealer sells it to you and loads a "Canned Map" to the bike for whatever accessories you add to it. They dont want to sell you the cables and cd because if you have even a slight brain you can do the work yourself, and they wont get to rip you off for the programming fee.
THe kit includes 2 cables 1 is a usb cable (* like a printer cable) and the 2nd one is a serial to special fitting cable to plug into the bike. The cd has the software you need, and the {"canned maps"). You simply look up your bike and its mods, and select the map that fits and load it. or you can modify it if you have special needs.
09-15-2009, 10:06 AM
#5 (permalink)
The Northern Redneck
Depending on your tuner, ( I have a Power Commander USB III ), you can use a USB to mini USB cable...It's the same cable as some digital cameras use for up loading direct to a computer.. I have the Power Commander info disc with the MAPs on it...I installed it to my laptop and from there it is simple to do..You just need to make sure you are choosing the best MAP for your application (by looking at the equipment in the MAP),ex pipes, intake, etc..With the computer hooked to the bike, you can monitor fuel rate, throttle position, etc with the bike running..just be careful not to burn your cables on the exhaust.....Blackdog
You can Sleep when ur Dead...
Baggers RULE !!!
HERD Member # 000015
09-15-2009, 02:30 PM
#6 (permalink)
I Just Finished Installing...
The Vance&Hines Big Radius 2-Into-1 Exhaust, High Flow Drak Air Filter Kit and Fuelpak on my 09 Rocker.
The Air Filter Kit was a snap to install, No problems at all.
The Big Radius 2-Into-1 Exhaust was an easy installation as well, No problems. Although, A second set of hands would of helped with aligning the exhaust to the cylinder heads.
The Fuelpac took me much longer than the stated 90 min. in the instructions. Gaining access to the ECU connector was difficult, Even using the recommended long Needle Nose Pliers. Routing the Fuelpac and the connectors through the tight space of the Bike frame was daunting and time consuming.
The most useful tool was a Coat Hanger wrapped with electrical tape to pull the harness into place.
The Fuelpac comes with Reference Settings for Bike Model, Pipe Model, Bike Year, Engine Size, ECU Level, Baffle Type and Air-Filter.
Programing the Module is fast and easy.
The aesthetics, Sound and performance were all worth the effort. I wonder how much $ my HD dealer would of charged for installing these items?
Anyway, I purchased the three items from one manufacturer for continuity of the products, Plus I liked the way they looked.
ATB Mike
09-16-2009, 08:41 AM
#7 (permalink)
Dr. D
Mt dealer charges $1735.00 for your installation
09-16-2009, 04:35 PM
#8 (permalink)
$1735.00
That's for parts and labor, Right?
Mike
09-17-2009, 08:55 AM
#9 (permalink)
Dr. D
yep, Yester day, I went in to this dealer and saw a bike just like mine with stage 1 and the same pipes and air cleaner (stage 1) they sold it to this guy brand new and told him it was a stage 2 bike and charged him $5000,00 more for it than I paid for mine. this dealer is a total rip
09-21-2009, 01:42 PM
#10 (permalink)
My Dixie Wrecked
I really appreciate the post from all of you..The HD dealer nearest to my house charges 1395.00 plus labor..Was told would be 3 hours min. on the labor..I have a very good idea what to do now...Thanks again..
Thomas Jefferson
Herd Member 50
| Thread Tools |
| Display Modes |
Linear Mode
