Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 09-18-2009, 01:02 AM   #1 (permalink)
Backfire, chortle, popping
New rebuilt motor: compression backing off and starts popping, chortle and etc. Exhaust still stock with inserts removed. Still using crossovers. '01 heritage Didn't do it before rebuild.
Harley5212001 is offline   Reply With Quote
Old 09-21-2009, 09:14 AM   #2 (permalink)
carbed or efi?
springer1 is offline   Reply With Quote
Old 09-23-2009, 06:03 PM   #3 (permalink)
Enthusiast
Smoker03's Avatar
If its carbureted, try richening the idle mixture a little at a time.
Smoker03 is offline   Reply With Quote
Old 10-06-2009, 02:54 AM   #4 (permalink)
Originally Posted by springer1 View Post
carbed or efi?
efi, rebuilt motor
Old 10-06-2009, 02:55 AM   #5 (permalink)
efi, rebuilt motor
Old 10-06-2009, 02:56 AM   #6 (permalink)
EFI, rebuilt motor, mapping the same
Old 10-06-2009, 08:40 AM   #7 (permalink)
senior citizen
SCHMIDTYS's Avatar
Not enough info from you ... can't diagnose from the symptoms you described .
Old 10-07-2009, 01:02 PM   #8 (permalink)
backfiring
Motor totally rebuilt. Runs great except when backing off throttle the exhaust starts compression backfiring, popping. Going down hill at 40 in third gear with no throttle. I've heard it could be air leak? and also a valve hanging up in guide? How do I check valve in guide? It is EFI, 2001 twin cam. New everything inside.
Old 10-07-2009, 02:47 PM   #9 (permalink)
Mentally unstable.
Ahhhhh....new info. No...not a valve guide, rather you're running lean.
You need to richen the fuel mixture up, or check for an exhaust leak on the rear pipe, if that's the ONLY pipe that's doing it.
If you're running too lean, it can do the same thing, but it's generally on BOTH cylinders, not just the rear one. Just having ONE cylinder do it sounds as if it's as simple as locating an exhaust leak at the head, or ar the pipe/muffler union.
HERD meber #10
Old 10-07-2009, 05:06 PM   #10 (permalink)
nitro freak
prodrag1320's Avatar
Images: 5
not a valve guide/valve prob,ive heard guys say that for ever,a valve isnt going to "hang up in a guide",then free up,once a valve seezes in a guide,motors spining so fast,the damage is done,its stuck,bent valve.you could have a ex. leak or its too rich way on the bottom and dumping raw fuel into the pipe,when this happens on a efi bike(like with a power commander,you zero out the first column,same princible with a carb,check you air/idle,lean it out a bit
kirby
vee twin racing
prodrag1320 is offline   Reply With Quote
vB code is On
