Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 10-01-2009, 01:26 PM   #1 (permalink)
98 FLSTS Has no spark
Hey folks,
I have a 98 FLSTS that is giving me fits. I was having starting problems so I put in a new battery. Bike ran great for a couple of weeks, then it sat for two weeks, went to go riding yesterday and it wont start. Bike kicks over fine, puled the plugs and held them to the head and no spark on either one!!! What the heck is going on, any help is greatly appreciated..
BigWaveDave is offline   Reply With Quote
Old 10-01-2009, 06:57 PM   #2 (permalink)
Does anyone know of an easy way to test the cam position sensor?
Thanks, Dave
Old 10-01-2009, 08:55 PM   #3 (permalink)
Appalachian American
XDixiecratX's Avatar
Big wave you ll get a lot more responce to this if you ll go to The New to the Community section and introduce yourself
THE HERD # 0001
XDixiecratX is offline   Reply With Quote
Old 10-01-2009, 10:12 PM   #4 (permalink)
Thanks XDixiecratX
I looked maybe I just missed it how would I do that? I am a long time motor head, scooters are the best though.. have more than 10, Harleys and dirt bikes.. Just need some help, damn bike and I aint going to the dealership..
Dave
Old 10-01-2009, 10:19 PM   #5 (permalink)
Slide up to the top of this page click forum and its at the top of the first page
THE HERD # 0001
Old 10-02-2009, 07:23 AM   #6 (permalink)
senior citizen
SCHMIDTYS's Avatar
Check your batt. voltage at the posts , should be more than 12.5 v. The engine will crank over with low volts but the ignition won't fire the plugs with low volts . Next with the engine running again check volts at the battery , should be over 13v . You'll be looking for the volts to increase as you raise the rpms and with the engine running the battery volts should be higher than when the bike is off .
You can disconnect the CKP and check resistance across the pins , you want to see no opens or shorts and between 1 - 1.5k resistance . Same with the crank sensor . Also disconnect the neg. battery cable and test for parasitic drain , should be less than about 0.7ma .
SCHMIDTYS is online now   Reply With Quote
Old 10-02-2009, 11:40 AM   #7 (permalink)
Now I'm going crazy, Ok got home last night, popped a beer and went to the man cave to tinker on the bike. For the hell of it tried to start it and it FIRED right up!! Then I ran it for about 5 minutes, ran perfect, turned it off, started it again, ran perfect.. Now beer is empty, go to fridge get another beer, old lady says take out the trash, trash taken out, come back 15 minutes later tried to start it, WONT START AND NO FFFIN SPARK, WTF!!!!
Old 10-02-2009, 07:23 PM   #8 (permalink)
Theres a loose or dirty connection somewhere, Id start at the battery then the starter, then the ign switch. If that dont do it Id hollor for Dave63.
THE HERD # 0001
Old 10-04-2009, 01:17 PM   #9 (permalink)
Thanks XD,
I will check again..
D
Old 10-04-2009, 01:36 PM   #10 (permalink)
Mentally unstable.
Do you have a crank sensor near the end of the oil filter? Check the connection at the plug. As well.....have the wife wiggle the plug gently, while you crank it.
As well..... check the connection of the +/- terminals at the coil. The wires that go there commonly get corroded, cause they're exposed.
Check your ignition switch under the dash too. You have positive feed wired that screw to it and if the one for the ignition is loose, ...........
HERD meber #10
vB code is On
