Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 10-03-2009, 11:48 AM   #1 (permalink)
compensator sproket removal
Is the lock nut on the compensator sproket left or right thread? How do you keep the crank from turning to break it loose? 93 fxsts-evo
rbpeck is offline   Reply With Quote
Old 10-03-2009, 11:52 AM   #2 (permalink)
Mentally unstable.
Lefty loosey, righty tighty. Normal righthand threading. Clutch hub nut is lefthand or reversed threading, though.
Put the bike in 4th gear and have someone sit on it and hold on the rear brake. Use a breaker bar.
Outside of using an airgun, (not recommended by most) or using the special ring gear tool to hold it, that works fine.
Stop in our New to the Community section and give us a shout, and tell us about yourself/bike.
HERD meber #10
Old 10-03-2009, 11:53 AM   #3 (permalink)
nitro freak
prodrag1320's Avatar
Images: 5
regular thread,trans nut is backwards.use air & an impact (1 1/2 socket)
kirby
vee twin racing
prodrag1320 is offline   Reply With Quote
Old 10-03-2009, 11:54 AM   #4 (permalink)
Mentally unstable.
HA! Beat you to it Kirby......
HERD meber #10
Old 10-03-2009, 12:09 PM   #5 (permalink)
nitro freak
Images: 5
i was going to say that!!! and you beat me to say you beat me!!!!!!!
kirby
Old 10-05-2009, 03:34 AM   #6 (permalink)
Use loctite red on reassembly .
Badinfluence is offline   Reply With Quote
Old 10-06-2009, 10:34 AM   #7 (permalink)
Thanks brothers guess ill have to borrow air-had her in2nd and rolled it against wall still wont break loose got pissed and had to walk away
Old 10-06-2009, 10:44 AM   #8 (permalink)
senior citizen
SCHMIDTYS's Avatar
There's a tool ya need if ya don't have air , it's a steel wedge that fits between the comp sprocket and the starter sprocket on the clutch hub and you can probably make one out of some steel stock from the hardware store . The tool is about 5-6 inches long , 1 and 1/4 inch wide and about 3/16ths thick . If you do some measuring you'll figure it out . It fits between the sprockets kinda like this \ with a little more angle to loosen and reverse it to tighten . The tool wedges between the sprocket teeth and holds them in place while you're cranking on your 1/2 inch breaker bar with a 3 foot pipe on the end !
Old 10-06-2009, 11:31 PM   #9 (permalink)
Bro
can I get enough slack in the primary chain to pull the compensator sproket without pulling the clutch?
Old 10-07-2009, 06:12 AM   #10 (permalink)
senior citizen
SCHMIDTYS's Avatar
Yup , but it's a bit of a struggle . Ya gotta loosen up on the plastic chain adjuster slide all the way . Don't worry ya can't bend the chain with your bare hands either .
vB code is On
