» Site Navigation |
» » » » Motorcycle Forums
» Links |
10-10-2009, 09:01 PM
#1 (permalink)
Removing the bags from a Heritage
Today, in order to clean behind them, I tried to remove the bags from my Heritage - two 1/2" nuts on the inside of the bags, no prob. Then I noticed that there's a metal strut that attaches the bag to the frame via a bolt, but between the bolt and the frame there's a rubber grommet.
I tried to remove that bolt but after a turn or so, the grommet was just twisting, and when I released the ratchet, it just untwisted, there was no way to continue loosening the bolt. There didn't appear to be a nut on the other side of the bolt that I could stabilize while I turned the front nut. Its possible that the nut was just sticking to the grommet and I could have been more forceful, but I didn't want to break the grommet or otherwise mess it up.
I wound up just carefully letting the bags hang by the grommet while I cleaned back there, but I was curious if anyone knows how to remove that bolt. (picture attached)
Any insight appreciated.
10-11-2009, 07:16 AM
#2 (permalink)
senior citizen
Join date August 09 and 1st post ? Ok ... that's a wellnut you're pointing at , just bust it outta there by any means and replace it with a bolt , lock washer and chrome acorn nut .
10-11-2009, 08:17 AM
#3 (permalink)
Thanks for the advice - and I guess if the grommet rips, I can replace that as well.
Sorry for not posting more, I'll try not to commit that offense in the future. :-)
10-11-2009, 08:29 AM
#4 (permalink)
senior citizen
10-11-2009, 09:26 AM
#5 (permalink)
Mentally unstable.
I have turrets. It would be impossible for me to join a forum and not post for that long.
HERD meber #10
10-11-2009, 11:27 AM
#6 (permalink)
 . I'm definitely a lurker. I'm a very new biker, so I am soaking up a ton of information. Maybe too much, a couple of my friends have suggested I loosen up a bit. Probably good advice.
10-11-2009, 11:41 AM
#7 (permalink)
HERD #00021
[quote=keithhu;150655]  . I'm definitely a lurker. QUOTE]
careful man, most of the wimmin here carry handguns. would hate to see you have an accident
Never let your schooling interfere with your education
LONG LIVE THE FIGHTERS
all our scars tell a story
10-14-2009, 05:05 PM
#8 (permalink)
My Dixie Wrecked
[quote=toorglide;150661]
You have to be the funniest guy on this forum
"A government big enough to give you everything you want, is big enough to take away everything you have"
Thomas Jefferson
John 11:16 Therefore Thomas, who is called Didymuss, said to his fellow disciples, "Let us also go, so that we may die with Him."
Herd Member 50
10-18-2009, 12:34 AM
#9 (permalink)
hi I removed my saddle bags completely with no problems All I did was turn the nut it was hard at first but I just kept on turning and it did get loose
11-10-2009, 10:29 AM
#10 (permalink)
There is a long bolt through the footpeg shaft that is a hex head. You'll need to somehow lock that down while turning the nut with a loooong extension. I had to go at it from the opposite side of the frame in front of the rear tire. I JUST had this exact same problem last night when removing the hard bags from my 07 Softail. I had to remove the one foot peg so I could get a hex head on the bolt. The other was not as problematic. I just noticed that your mounting bracket isn't behind the footpeg, but there should be a 9/16ths nut behind there.
| Thread Tools |
| Display Modes |
Linear Mode
