Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 10-15-2009, 12:44 PM   #1 (permalink)
just me
driller73's Avatar
Crankcase Breather
My breather hose is running under under my trans. It has a bolt in the hose with a clamp around it. Does anybody know if this is a problem? It seems that I have a lot of pressure building in my rockerbox. I have a leak that i have fixed once and now again. Having a hard time aligning the box covers. Its a 1992.
No such thing as dumb questions.....just dumb people
driller73 is offline   Reply With Quote
Old 10-15-2009, 03:10 PM   #2 (permalink)
nitro freak
prodrag1320's Avatar
Images: 5
if thats your actual breather line,im surprised its not leaking everywhere,where on the motor dose the line go?if its the 1/4 npt hole behind the oil pump,it needs to be open if
its`91- down,if its `92 up you have head breathers
kirby
vee twin racing
prodrag1320 is offline   Reply With Quote
Old 10-15-2009, 03:23 PM   #3 (permalink)
Mentally unstable.
Your profile says "softail custom".
What year?
If that's what I'm thinking, it's your oil tank drain hose. Take the bolt out and all your oil drains out. It's how you change your oil......
It has nothing to do with venting.
Your head vents vent into the aircleaner housing, unless someone placed aftermarket breather tubes on the bike with an aftermarket airfilter housing.
If so, that hose should go up to the head vent(s).
The one you have with the bolt in it, is your drain hose.
HERD meber #10
Old 10-15-2009, 03:36 PM   #4 (permalink)
nitro freak
Images: 5
thats why i asked where it went to the motor,he could have an non head breather evo,ive had them come in the shop,where they had alittle oil coming out of the breather hose,so they plugged it (and gaskets started leaking) if its the drain,either he just got the bike,or dosnt change oil very often
kirby
vee twin racing
Old 10-15-2009, 03:48 PM   #5 (permalink)
Mentally unstable.
kirby
vee twin racing
Gotcha, Kirby..... just seems odd that someone went to the trouble to not only use a bolt, but a clamp as well......
HERD meber #10
Old 10-15-2009, 05:45 PM   #6 (permalink)
MrMarty51's Avatar
Just wanted to be sure none of them crankcase fumes made it out into the atmosphere.
Herd Number,triple Zero three zero
If Ya do`nt want to do an intro then expect no answers.
MrMarty51 is online now   Reply With Quote
Old 10-15-2009, 06:25 PM   #7 (permalink)
just me
driller73's Avatar
It's a 1992
If it is a drain then I have 2. I have changed the oil with a hose that goes under the trans as well. I bought it used and it has a hypercharger the bolts that go into the head which I thought were the breathers are just regular bolts. So that might be the problem. The hose with the bolt/clamp on it comes out of the bottom of the engine block. It is a 1992.
Old 10-15-2009, 07:42 PM   #8 (permalink)
nitro freak
Images: 5
sounds like the breather to me,take the bolt out,
kirby
vee twin racing
Old 10-15-2009, 07:48 PM   #9 (permalink)
Mentally unstable.
kirby
vee twin racing
Ditto.
HERD meber #10
Old 10-15-2009, 07:56 PM   #10 (permalink)
nitro freak
Images: 5
had a guy come in with a twin cam because the p/rod covers kept leaking,took the A/C off and was running a volacity stack,put 2 fittings in the heads and connected them together,go figure
kirby
vee twin racing
vB code is On
