Was then frame checked via Comp-U-check, or "assumed" that it wasn't undamaged? Your insurance should have paid to have this checked....
If the frame was damaged, and your motor mounts, both lateral and vertical, are incorporated, a slight bend can throw everything off from the front to the rear and cause issues.
Comp-U-check is a frame alignment machine that can check frames with bikes both semi-disassembled and completely disassembled. We used them, out of Philly, PA when I raced......... and crashed......... {{frown}} It costs about $700 to have a frame checked but if you had an accident, your insurance has a liability to make sure your returned bike is like it was prior to the wreck, and not "assume" it's ok......based on someone's eyeball opinion.
CrashDamageRepair.com - Motorcycle Frame Straightening
Motorcycle Frame Straightening Repair
HERD meber #10
