Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 10-23-2009, 02:14 PM   #1 (permalink)
Baker Plus One Oil Pan
Anyone have success running Baker Plus One oil pan on '07 Deluxe? What is temp lowering pros/cons vs. oil cooler?
scottcro is offline   Reply With Quote
Old 10-26-2009, 10:46 PM   #2 (permalink)
Appalachian American
XDixiecratX's Avatar
You ll have more sucess on this page if you ll pay a visit to the
New to the Community thread at the top of this forum and introduce yourself so we can give you a proper Welcome!
THE HERD # 0001
XDixiecratX is online now   Reply With Quote
Old 10-27-2009, 09:11 AM   #3 (permalink)
The Northern Redneck
Blackdog 15's Avatar
Dixie is up and on patrol...Yeah Haw !!!....red lights a spinnin"....
You can Sleep when ur Dead...
Baggers RULE !!!
HERD Member # 000015
Old 10-27-2009, 10:16 AM   #4 (permalink)
Mentally unstable.
Just my opinion......
I believe you'd see more of a temp change with a cooler and synthetic oil then a +1 pan.
http://www.bakerdrivetrain.com/flt/index.htm#p1p
Very nice product, but it's also tucked up pretty high in the frame rails, precluding it from a lot of air exposure, (softail) unlike a Dyna, where it would hang lower.
Baker claims that it decreases oil temps by 10* on an 80* day. You can gain that by just switching to synthetic oil on a stock bike....
Very nice looking product. Well made. Cast or billet....
HERD meber #10
Old 10-27-2009, 10:23 AM   #5 (permalink)
oil cooler & Mobil 1.....does the trick for me....and is less work to install...
Baggers RULE !!!
Old 10-27-2009, 10:24 AM   #6 (permalink)
Mentally unstable.
And you rode yours in hotter temps this summer and got better then just 10* lower results, right Lee?
HERD meber #10
Old 10-27-2009, 10:25 AM   #7 (permalink)
Yip, dropped mine 25 + degrees...plus the synthetic is the "E" ride ticket for cold weather starts too....
Baggers RULE !!!
Old 10-27-2009, 10:31 AM   #8 (permalink)
Too Badd Customs
Too Badd's Avatar
Pulled this from the site.
The feed and return on a stock pan are located within a 2 inches of each other in the front of the pan. BAKER+1 pan has the feed located in the rear and the return in the front for more compete system circulation.
I assume the thought process of Baker is that with better circullation it helps to dissipate the heat.
I believe that the aluminium baffles come into play as a cooling factor as well.
These are merely assumptions on my part.
Too Badd is offline   Reply With Quote
Old 10-27-2009, 10:45 AM   #9 (permalink)
Mentally unstable.
The feed being moved to the rear is a better design and done so you'll never have an oil starvation issue on hard accelerations, when oil's slung to the back of the engine.
The baffles are internal and are added to prevent oil transfer, and has to be done in deeper pans. Baffeling is supposed to prevent this, but doesn't always, especially if the feed is in the front.
I agree that circulating the oil differently in the pan would seem to help lower temps, but if it only drops oil temps 10* on an 80* day, it's gonna do less as it gets hotter out, or in slow traffic.
JUST changing to synthetic oil alone will drop oil temps 15-20*.
An oil cooler increases the oil level as well, however, it moves oil AWAY from the reservoir, allowing it to shed heat. Adding a 1 qt oil pan, just gives you one more qt of oil.
I see a great advantage of adding the Plus-one oil pan, with a cooler and Synthetic oil. This way, the oils cooled better, and you've increased the capacity by almost 2 qts. That's beneficial to anyone riding in hotter climates, or heavy, slow summer traffic.
HERD meber #10
Old 10-27-2009, 11:05 AM   #10 (permalink)
Too Badd Customs
Too Badd's Avatar
Great info Dave.
You are a wealth of knowledge.
vB code is On
