vibration. - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 12 (permalink) Old 11-28-2009, 11:13 AM Thread Starter
pauld's Avatar
Images: 16
vibration.
I have had my first Harley, Fat Boy Lo, for about a month and I am trying to ride as much as possible. (Only put 150 miles so far ).
My question is about vibration. At highway speed (for me its speed limit-65) in 5th gear, my feet can feel the vibration on the floor pegs. It is a "fine" vibration that almost tickles the bottom of my feet. I feel the same thing on my handle bars.
Not having owned a HD before, and hearing different things about vibration, does the above sound normal to you or should I get it checked?
pauld is offline
post #2 of 12 (permalink) Old 11-28-2009, 01:10 PM
The Northern Redneck
Blackdog 15's Avatar
Might be a balance on your tires...new tires can do this too...
If Ya Ain't the Lead Dog, The View NEVER Changes
You can Sleep when ur Dead...
Baggers RULE !!!
http://www.youtube.com/watch?v=bTrb4YGkSOU
HERD Member # 000015
Blackdog 15 is offline
post #3 of 12 (permalink) Old 11-28-2009, 01:15 PM
SCHMIDTY's Avatar
Balanced engine ... shouldn't be vibrations like you say . Could be tires as said .
SCHMIDTY is online now
post #4 of 12 (permalink) Old 11-28-2009, 02:14 PM
It's normal on my Night Train. At lower rpm's there's almost no vibration. I think you're just feeling the Softail "buzz".
Dyna's and Touring HD's are the opposite. They vibrate like crazy at idle but smooth out quickly when moving.
BoomerBob is offline
post #5 of 12 (permalink) Old 11-28-2009, 02:24 PM
stock HD tires(Dunlop) are known for going out of balance/cupping/etc....I had some vibration and cupping issues till I switched to Metzlers....
Baggers RULE !!!
post #6 of 12 (permalink) Old 11-28-2009, 05:53 PM
kc5gxc's Avatar
You could try some dyna beads in the tires....might take care of it.
Good Luck....Pete
kc5gxc is offline
post #7 of 12 (permalink) Old 11-28-2009, 06:48 PM Thread Starter
pauld's Avatar
Images: 16
Hmm...might be the "buzz". When I up the rpms...i get the vibration IF I am moving..
Example..2nd gear at 35mph...i get the vibration...same in 5th gear at 65
pauld is offline
post #8 of 12 (permalink) Old 11-28-2009, 06:51 PM
at 150 miles, it's likely that it's not tires, cupping of tires or otherwise. Chances are, at highway speeds, or even less then highway speeds, it's due to the ubber lean a/f mixture.
One of the things i've noticed with umpteen bikes that I've owned, worked on, or both, is that once you fatten the air/fuel mixture from factory settings, most vibrations in the bike disappear.
Just sayin'...
Then again.....if this is your FIRST harley.....this ain't no jap bike. It vibrates.
They're not called "Milwaukee Vibrators" for nothing..........
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #9 of 12 (permalink) Old 11-28-2009, 09:01 PM Thread Starter
pauld's Avatar
Images: 16
Yeah, and thats the point. My FIRST HD. Its not a complaint. Its me wanting to know everything I can.
pauld is offline
post #10 of 12 (permalink) Old 11-28-2009, 09:25 PM
Trade School Alumnus
Eleft36's Avatar
Check the air pressure in the tires.
My '07 Custom doesn't do that at any speed.
Al
Stock CVO 110 Mufflers, K&N A/C, Stock Heads, SE 103" BB kit, Andrews 26H Cams, Mustang wide Touring Seat, Stock Bars, H-D Oil Cooler, 1990's LeatherWorks inc Saddle Bags & Modified HD Deluxe Guards, H-D Luggage rack, H-D Windshield, SE Fork Brace, SE Comp, Thunder Max A/T, S&S Lifters, Zipper's dual piston tensioners, Progressive Mono tubes & 422 Shocks, SCRC 524
Bagger set up to ride comfortably
Eleft36 is offline
