Moving front turn signals - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 3 (permalink) Old 02-24-2014, 06:43 PM Thread Starter
jopagocks's Avatar
Hello all. 2012 Fatboy and I want to move the front turn signals down to the auxiliary lighting that I have. Seems like there are two holes that can hold each signal but not sure if I can mount directly through those holes or if I need a mount. Anyone have any ideas? Only interested in relocating them to aux light bar
1984 HD Sportster XLH 1000 (sold)
2012 HD Fatboy(RIP)
2014 HD Street Glide Special
Above all, ride safe!! Cheers!!
:biking:
jopagocks is offline
post #2 of 3 (permalink) Old 02-24-2014, 07:04 PM
The aux lighting is the same on other touring models, but the turn signal lights are completely different. I believe you can use something similar to the street glide ts mounts that mount to the sides of the nacelle. Unless you have a windshield.
I put a set on my friends rk. We simply bought the aux lighting kit with the proper signals and bit was plug and playm
Sent from Motorcycle.com App
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 3 (permalink) Old 02-24-2014, 07:13 PM Thread Starter
jopagocks's Avatar
Ok. That sounds right. I appreciate your response. I'll look into those mounts. I do have a windshield so that might affect the placement slightly.
2012 HD Fatboy(RIP)
:biking:
