tapping into the electrical power - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 12-25-2010, 11:31 AM   #11 (permalink)
SCHMIDTYS's Avatar
My bud has a Handlebar mount lighter tap , it attaches to the front master cylinder clamp . It's either an H-D or Kuryachyn product . I wired it from that HDI wire in the headlight nacelle . It's got a sealing cap for when not in use . Actually I think it was originally a handlebar mount cigarette lighter .
Old 12-25-2010, 12:11 PM   #12 (permalink)
www.bcvtwin.com
colonelangus's Avatar
Originally Posted by SCHMIDTYS View Post
Also , if you don't feel like running wires under your tank , pull your headlamp out and locate the 2 HDI accy. wires . The HDI wires , O/W and BLK are usually taped to the headlamp harness and are capped , only used on International model H-Ds . The HDI O/W wire is on the accy . fuse and is switched with the ignition .
mine didnt have the wires your talking about thats why i had to do it how harley would have ..if you look at the wiring schematic it shows the headlight wiring with an extra pigtail and plug for the fender light and a capped yellow for spots ..i just got the multilock connector from the dealer and made my own as shown in the pics i also have a springer classic headlight and harness i purchased on ebay from the states and it only had the yellow for the spots
colonelangus is offline   Reply With Quote
Old 12-25-2010, 12:20 PM   #13 (permalink)
SCHMIDTYS's Avatar
HDI wiring is part of the main harness . As far as I can see from your pics you did it correct for your application .
Old 12-25-2010, 07:58 PM   #14 (permalink)
www.bcvtwin.com
i tried to make it look factory figured if it worked for them lol
Old 11-25-2012, 08:39 PM   #15 (permalink)
Burgundy9's Avatar
I love this site and the search feature...
Burgundy9 is online now   Reply With Quote
Old 11-26-2012, 09:10 AM   #16 (permalink)
squeekie's Avatar
These little fuse holders are a really great idea if you want an easy way of taking an additional output from any existing blade fuse holder/fuse box.
Simply remove the existing fuse, plug in the piggy back unit where the fuse you just reoved was, reinsert the fuse into the piggy back unit, connect your new assessory to the wire, insert and appropiate fuse into the other fuse socket on the piggy back unit and thats it - two fused outputs from one.
You should check that the wiring feeding the existing fuse can take the extra load you are adding.
Ward, don't you think you were a little rough on the Beaver last night?
2005 XL1200C Vance & Hines Staggered Short Stacks w/QQ Thunder Monster Baffles, D & M chrome spike air cleaner, 48, 185 jets, 12" Burly's, Mustang Cyclone solo seat, Progressive 412 shocks.
squeekie is online now   Reply With Quote
Old 11-26-2012, 09:23 AM   #17 (permalink)
SCHMIDTYS's Avatar
That's for the Auto-Fuse style fuses. Do they sell those for the Mini-Fuse style fuses used on H-Ds ???
Old 11-28-2012, 02:58 AM   #18 (permalink)
Badinfluence's Avatar
You can find Mini-Fuse style holders at Parts Express. Have bought many things from them.
Badinfluence is offline   Reply With Quote
Old 11-29-2012, 06:16 AM   #19 (permalink)
Burgundy9's Avatar
Those fuse taps are sweet! I installed some Boss speakers behind a Memphis Shades bat wing. I tapped into the orange/white wire, per recommendations here, and it's golden.
Old 11-29-2012, 10:46 PM   #20 (permalink)
duecedog's Avatar
Images: 9
I will add my .02 to this. The original wiring was designed for a specific voltage/amp load. If you add (or double) to the demand it may be too much for the wiring. I was going to use one of these to add some lights to my car. After researching it on several forums I decided that I didn't want to take a chance on smoking any wiring. I believe most GPS units draw around 5 volts/3 amps so you'd probably be okay, but I just wanted to make sure you're cautious on this.
The power port that Shmidty is probably referring to may be the one that I have on my bike.
I use it for my GPS and a GoPro camera.
Vietnam Vet.
NJ PGR member.
duecedog is offline   Reply With Quote
