Fatboy Oil Capacity - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 10 (permalink) Old 02-21-2011, 01:00 PM Thread Starter
Fatboy Oil Capacity
Hi can some one advise the engine oil capacity on my 09 Fatboy picked up 3 US quarts today, Dealer told me this would be enough [ rode 50 miles in some real miserable wheather to get it] but checked Handbook when i got home and states 3.50 US quarts? just didnt want to drain it all out and find i havent got enough.
hottdiggetydog is offline
post #2 of 10 (permalink) Old 02-21-2011, 01:02 PM
3.5 US Qts, with filter change. Go back and kick your dealer in the arse.
SPECS:
Front Tire: 140/75R17 67V
Rear Tire: 200/55R17 78V
Length: 94.3 in.
Seat Height: 25.4 in. (laden) / 27.5 in. (unladen)
Ground Clearance: 5.10 in.
Rake Steering Head/Trail: 31 / 5.80 in.
Wheelbase: 64.5 in.
Track Width: N/A
Fuel Capacity: 5.0 gal.
Oil Capacity: 3.5 qt.
Dry Weight: 694.0 lbs.
Running Order: 714.0 lbs.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 10 (permalink) Old 02-21-2011, 01:27 PM
SCHMIDTY's Avatar
I haven't found one yet that I can get more than 3 qts. in . Wanna know why ? I'll tell ya why . Those are dry unweighted specs ! ! !
If you have a Softail that's at a service interval it's gonna take 3 qts. in the oil tank . If ya put 3.5 qts. in it's gonna read over full on the dipstick after ya run the engine !
Oil cling !!! Ya can't drain all the oil outta the engine , there's always gonna be about a half quart left in the engine after ya drain the oil .
If ya rebuild the engine and put it all back together with assy. lube then you would put 3 qts. in the oil bag and pre-fill the filter ... that equals 3.5 qts. .
A dry Softail engine takes 3.5 qts. !
SCHMIDTY is online now
post #4 of 10 (permalink) Old 02-21-2011, 01:31 PM
hockeydawg12's Avatar
On my '05 Fat Boy, I went through this. Followed the book and filled it with 3.5 qts...Oil was up to the bottom of the fill neck, overfilled. I pulled some out. Next time put in 3.25 qts. Still alittle too much. Schmidty is right, 3.5 is too much. And I change the filter every time I change my oil.
Current - 2012 FLHTK Ultra Limited
Previous - 2005 FLSTFI Fat Boy
I don't know. I never smoked AstroTurf. ~Tug McGraw, when asked if he preferred grass or artificial turf
If the Bible has taught us nothing else, and it hasn't, it's that girls should stick to girls' sports, such as hot oil wrestling, foxy boxing, and such and such. ~Homer Simpson
hockeydawg12 is online now
post #5 of 10 (permalink) Old 02-21-2011, 01:31 PM
I stand corrected. 3 qts.
(Kick me in the arse)
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #6 of 10 (permalink) Old 02-21-2011, 01:49 PM
SCHMIDTY's Avatar
Shame on Yooooo !
post #7 of 10 (permalink) Old 02-21-2011, 03:52 PM Thread Starter
Thanks guys for your replys, made my ride a little more worthwhile hearing this weather in UK awful, Salt everywhere, bikes covered in that ACF 50 corrosion protector , works great that stuff.
post #8 of 10 (permalink) Old 02-21-2011, 08:11 PM
butch61's Avatar
Images: 5
i would suggest a moco service manual. alot more info than the owners manual that came with the bike
butch61 is offline
post #9 of 10 (permalink) Old 02-21-2011, 08:46 PM
unless you pull the oil out of the sump, you will only get 2.5 to 3 qts in. Below is a link that explains how to get all oil (pretty much) out. I have used and it works quite well. be sure to have an emtpy container to place hose in when you start engine.
Don't use if you don't think you are capable. Also, use a stand of some type to have bike level.
http://www.hdtalking.com/archive/index.php/t-767.html
hogger is offline
post #10 of 10 (permalink) Old 02-22-2011, 06:35 AM
good info. yes it says capacity is 3.5 quarts, and yes, if you are changing your oil 3.5 is too much. I did that once, (my wife use to have a turkey baster )
3 quarts, bike sitting level (not on the kick stand) to check
and good luck getting the filter of while maintaining all of the skin on your knuckles
Rockerbox1 is offline
