Primary cover leak - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 3 (permalink) Old 05-21-2011, 02:59 PM Thread Starter
Primary cover leak
I have 00 fxst and I noticed an oil leak. It seems to be where the drain screw is or where the cover bolts on. Any thoughts ?
fire48 is offline
post #2 of 3 (permalink) Old 05-21-2011, 03:26 PM
DILLIGAF
elvislives's Avatar
Start with tighten the screws if doesnt work. then drain primary and look into.. if it is the drain plug put teflon tape on threads.
elvislives is offline
post #3 of 3 (permalink) Old 05-22-2011, 08:08 AM
SCHMIDTY's Avatar
More likely the inner primary seal is leaking . The oil runs down the back side of the inner primary and finds the lowest point to drip from . When the bike is on the jiffy stand the lowest point would be at the drain screw . Use a mirror and flashlight to look at the back of the inner primary to locate the leak . The fix is to remove everything and replace the seal .
SCHMIDTY is offline
