04 Night Train- tail light/running lights not working - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 1Likes
  • 1 Post By Dan89flstc
post #1 of 7 (permalink) Old 03-18-2017, 09:05 PM Thread Starter
I am hoping someone can help figure this out??? Recently bought bike, signal lights and brake light works fine. Tail light and running lights don't work at all??? Checked the fuse, checked wiring connections but didn't see any issues. The lights are LED's so I am not sure if there is a fusible link somewhere or what the issue is??? Can anyone tell me what to do? I have been working on it for a few days and am totally baffled!!!!
Rodteg is offline
post #2 of 7 (permalink) Old 03-19-2017, 08:39 AM
SCHMIDTY's Avatar
Unplug the LED ballast and plug the harness back together as stock to see what happens. If lights function at all the ballast is bad.
SCHMIDTY is online now
post #3 of 7 (permalink) Old 03-19-2017, 08:54 AM
We just went thru this with wife's Road King. Her "high/low" switch was bad, dealer corrected it, (was under warranty), but also, could be starter switch has dirt in it now allowing switch to operate properly. The headlight and running lights are off when the starter switch is engaged. Good Luck
newscnels is offline
post #4 of 7 (permalink) Old 03-19-2017, 10:17 AM
Dan89flstc's Avatar
The bike being discussed is an `04 Softail...
The problem has nothing to do with the starter switch or the high beam/low beam switch.
The running light circuit is directly powered by the lights fuse, there is no switch in this circuit.
Also, the headlight does not go out when the starter is engaged, the headlight circuit is powered by the headlamp circuit through the hi/low beam switch, which is directly fed by the headlamp fuse.
Rodteg: You say you checked the connections, what did you actually do? Have you checked for system voltage at the blue wire in the connections?
Did you check for power at the output side of the fuse?
SCHMIDTY likes this.
Dan89flstc is online now
post #5 of 7 (permalink) Old 03-19-2017, 12:51 PM
Frozen Member
naknekpete's Avatar
I just had to learn this circuit myself. My problem is apparently a blue wire shorting to ground between the harness neck connection and the front signals that was causing the fuse to blow.
Dan's right. For some reason the headlight circuit is also a blue wire but a totally separate circuit from the blue wire circuit marked "lights" at the fuse block. The only place the "light" circuit goes is to to the tail light and to the front turn signals. Its one of the simplest circuits on the bike.
Do you have a meter or test light? One is needed to do more than a look and wiggle. The only things you can tell without one are to look at the fuse and if thats really good, the front signals should be lit as running lights, not just working as blinkers.
If you do have one, this circuit is switched so the ignition switch has to be on to test past the fuse block. As Dan said, 1st check for voltage at the fuse block and also make sure your fuse is actually good. Sometimes a fuse will be bad without looking blown. If those check ok, check for power on the blue wire at the harness connection to the rear fender. If you have that, I would suspect the LED ballast as Scmidty said, or the blue wire in between the harness connection and the tail light. If your brake light works the ground is good.
naknekpete is online now
post #6 of 7 (permalink) Old 03-20-2017, 09:22 PM Thread Starter
Thumbs up Faulty fuse
Thank you very much -naknekpete- the fuse looked fine but when I tested it with multimeter it proved faulty. I would have never guessed to even check that!!!! My wife thanks you as well, guess I was getting a little grumpy??? Lol.
Rodteg is offline
post #7 of 7 (permalink) Old 03-20-2017, 09:26 PM
Frozen Member
naknekpete's Avatar
Youre welcome, glad I could help!
