LED run light not on - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 2Likes
post #1 of 11 (permalink) Old 06-15-2017, 09:56 PM Thread Starter
HDB07's Avatar
Hi
I have a 2013 Heritage Classic. 35000 miles. I put LED tail lights (68127-10, 68128-10) on it right after I got it. Today I seen that the left run light was not coming on.
It was late, hot, & dark when I got home tonight but I pulled the seat & didnt see the thing I remember putting on, but that could have been on the 07 I had.
I have a brake/run/turn signal kit on it (69461-06A) (I think) they do work that way & everything works but the one run light.? Did the 13s come with the brake/run/turn signal on it because I dont remember putting it on there.
I have been looking at the service manual & instruction sheets. I am still lost.
Any ideas what to look for would be appreciated!
Thanks is advance
Bill Hi
HDB07 is online now
post #2 of 11 (permalink) Old 06-16-2017, 04:49 AM
Viet Nam 69/70
harvey13118's Avatar
A bad bulb?
Life: VFW, NRA, NYSRPA(NYS Rifle Pistol Association)
2 favorite signs
CAUTION we do not dial 911 first.
DANGER if you are reading this U R in range.
05 FLSTC, 08 FLHTCUSE3
C4 IRONBALLS
2016 Ironbutt 1226 miles 19.5 hours
harvey13118 is online now
post #3 of 11 (permalink) Old 06-16-2017, 06:20 AM
Poser Member # 99
big john@dog's Avatar
Images: 5
Got a test Light see if you have power going to it and you ground for the light broken wire or rubbed thru . Bad LED bulb . It could Happen . First see if you have power and we can go from their we cant test it for ya from here
Check the plugs for corrosion
Jimmers likes this.
big john@dog is offline
post #4 of 11 (permalink) Old 06-16-2017, 07:02 AM
Jimmers's Avatar
^^^^yep what he said about checking power with a multi-meter to see if any voltage is present. Then if not, you can trace the wire back to the connections, fuse box, etc. You do have a multi-meter don't you. Handy for these kinds of problems. It's rare a LED burns out, but a possibility. Having a good service and electrical manual is suggested too. Good luck!
2015 Electra Glide Ultra Classic
Mysterious Red Sunglo/Blackened Cayenne Sunglo
Stage 4 Kit
ThunderMax Tuner
Vance & Hines True Duals
RC Component mufflers
Jimmers is online now
post #5 of 11 (permalink) Old 06-16-2017, 07:55 AM Thread Starter
HDB07's Avatar
Thanks guys. That was my thinking but though I would see if anybody had other ideas.
Yes, I have all that.
Bill
HDB07 is online now
post #6 of 11 (permalink) Old 06-16-2017, 09:37 AM
norm9278's Avatar
Generally the LED's are attached to a circuit board. They tend to loose internal connections, crack, smoke gets out, etc. Your DVOM is your friend.
norm9278 is online now
post #7 of 11 (permalink) Old 06-17-2017, 07:40 AM Thread Starter
HDB07's Avatar
I found it! !
I took the tail light off & checked all the electrical connections that I thought would have voltage to them & they checked out. Then I messed around with things that I wasnt sure that I knew what I was doing & said this is probably over my head. Put it all back together & went for a ride.
While riding ,I though you dumb but!, you didnt check under the fender! Well I guess the tire was hitting the wires under there! I am now in the progress of splicing a wire. I guess me & my lady need to lose some weight & carry less stuff when we ride or hit less bumps. LOL
Thanks for all of your help
Bill
PS not trying to show how dumb I am, but what is DVOM? Never heard that before.
OHEhsc likes this.
HDB07 is online now
post #8 of 11 (permalink) Old 06-17-2017, 07:43 AM
Breeze3at's Avatar
Digital Volt Ohm Meter = DVOM
I'm a no hyphen (-) American.
Pete / Breeze .380
Breeze3at is online now
post #9 of 11 (permalink) Old 06-17-2017, 07:45 AM
Jimmers's Avatar
DVOM = Digital Volt / Ohm Meter...I think!
Stage 4 Kit
ThunderMax Tuner
post #10 of 11 (permalink) Old 06-17-2017, 07:46 AM
Jimmers's Avatar
Oops...Breeze beat me to it!!!
Stage 4 Kit
ThunderMax Tuner
