Replacing Tappet Blocks - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 3 (permalink) Old 07-08-2012, 03:29 PM Thread Starter
I have a 2000 Night Train and the tappet blocks have peeling chrome.. I want to replace them - can this be done inframe?
What's the best way to remove them.
Thanks
bmilne1957 is offline
post #2 of 3 (permalink) Old 07-08-2012, 03:48 PM
Yes. The tappet block covers are just that: covers.
However, unless you're going to remove the gas tank, rockerboxes and pull the rocker arms to reuse your solid, nonadjustable pushrods, you'll have to cut the pushrods and replace them with adjustables. (Quick-install pushrods)
Screamin Eagle makes them. $145 a set. Comes with new upper pushrod tubes as well, which are shorter for adjustment.
It's a 2-3 hour job with a lift and bolt cutters for the old pushrods.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 3 (permalink) Old 07-08-2012, 03:48 PM
Guitar NOT Gator
gtrman66's Avatar
Dang, Dave already beat me to it.
....and corrected me, I gave EVO advice.
2016 FLHTK - 18 miles and counting
2004 FXSTSI - 10,000 miles and counting
http://www.doolinband.com - the band!
Dr. Rick "Superman" Doolin 1970-2014. Miss you bro.
Proud member of the NTC (North Texas Crew)
gtrman66 is offline
