Tire air pressure - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 11-12-2012, 07:28 AM   #11 (permalink)
2008 Heritage
MDGeorge's Avatar
Originally Posted by harley rider View Post
depends on the tire too. Is it the same tire that the factory put on? Some tires use more air pressure to support the same weight, in which case you would have to put in that extra pressure if you are supporting that much weight.
Here's what i was told: Find out how much weight is on the wheel (weigh it somehow) for your normal riding conditions and add a bit onto that for when you have a few too many burritos for lunch. Read on the sidewall of the tire what it's maximum weight carrying capacity is at full pressure. Calculate what percentage of that maximum capacity the wheel is actually carrying (from when you weighed it) and multiply that percentage times the maximum pressure written on the sidewall. The result is the pressure you should be running. If you increase what you are carrying like loading up for a trip or riding two up for any distance, increase pressure accordingly. At least that's how it was explained to me by a guy that started riding around the time god was born.
what?
Taming the Beast
MDGeorge is offline   Reply With Quote
Old 11-12-2012, 07:31 AM   #12 (permalink)
On Probation
HDSickness's Avatar
Depends if you are running a good synthetic air or some cheap dino air........just sayin'
Confuse a liberal.....use facts and logic.
_____________________________________________
2010 Ultra Limited FLHTK
SE Ventilator
Jackpot Stainless Header
Jackpot Slip-ons
SE Super Tuner
I'll try to be nicer........if you try to be smarter.
HDSickness is offline   Reply With Quote
Old 11-12-2012, 07:51 AM   #13 (permalink)
MPG'S? Who gives a
Craiger's Avatar
Images: 8
Always go with what it says on the TIRE. No matter what vehicle you're dealing with.Check tire pressures COLD.
Avoid using winter air though.
08 FLHTC. Breathing well and getting lots to drink.
Craiger is offline   Reply With Quote
Old 11-12-2012, 09:44 AM   #14 (permalink)
Read the book again. They give two readings. One for solo...one for 2 up. The 42 is for 2 up.
Bill D.
kg5ie
2009 FLSTC
kg5ie is offline   Reply With Quote
Old 11-12-2012, 09:48 AM   #15 (permalink)
MPG'S? Who gives a
Craiger's Avatar
Images: 8
So, What if the tires are no longer oem ?
Old 11-12-2012, 10:34 AM   #16 (permalink)
NC King's Avatar
Originally Posted by ccc888 View Post
Hi, I was confused, I have 2010 fanboy lo, what is the proper air pressure of front tire and rear tire? According to owner's manual front should be at 36 psi, rear should be at 42psi.
The manual is your best reference. I run a few pounds softer in the rear like your dealer said. The bike rides a little smoother. Dont go so soft it affects handling. To little air pressure will cause a build up of heat and blowout. To much air will cause over pressure and blowout. I run the front tire at what the manual recommends the bike handles best. Never go over the pressure on the sidewall for oem or non oem tires.
So the sidewall will give you the max pressure. The manual is a recommendation from the manufacturer and you can play with a few pounds for your comfort.
Clear as mud right?
NC King is online now   Reply With Quote
Old 11-12-2012, 02:39 PM   #17 (permalink)
03 CVO RK
GotGold's Avatar
Hi, I was confused
So reading through this thread your all straightened out right?
"Our lady of blessed acceleration don't fail me now."--- Elwood
GotGold is offline   Reply With Quote
Old 11-12-2012, 03:44 PM   #18 (permalink)
ccc888's Avatar
Yes , thank u guys
ccc888 is offline   Reply With Quote
Old 11-12-2012, 03:45 PM   #19 (permalink)
chasarms's Avatar
Michelin states in their literature to refer to the owners manual. Maybe they are the exception, but they design their tires to spec to factory.
2005 Electra Glide Classic FLHTCI
Black Cherry Pearl
chasarms is offline   Reply With Quote
Old 11-12-2012, 04:22 PM   #20 (permalink)
Ray-zer's Avatar
I like to take care of my ride, so I may hike up to the top of a mountain and bottle up some air and store it at home for just such an occasion.
2012-FLHTK-solid black
Comes with enough chrome IMHO
Ray-zer is offline   Reply With Quote
