Tire air pressure - Page 4 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 11-13-2012, 03:48 PM   #31 (permalink)
On the fence!
RDK09's Avatar
Originally Posted by Ray-zer View Post
HD doesn't make it easy to check tire pressure on the Ultras. I know that's no excuse for not checking tire pressure, but it sure is a pain.
Originally Posted by lakeforktx View Post
28 spoke wheI agree that its a bitch to check the air on the 28 spoke wheels....I found that you can bend the stem over a little bit and your guage will go on a lot better...I hate the 28 spoke wheels...
Here ya go, i haven't gotten one yet but its been saved in my favorites
Valve Stem Extension | Genuine Motor Accessories | Harley-Davidson USA
"09" Road King
"10" Forty-Eight
RDK09 is offline   Reply With Quote
Old 11-13-2012, 05:00 PM   #32 (permalink)
Flat Land Redneck
Old Coot's Avatar
Images: 25
Originally Posted by Silverback View Post
Go with the recommendations in the Harley manual. Adjust for your load (weight of you, your rider and baggage -- don"t be lazy about adjusting for different loads).
The number on the sidewall is MAX pressure the tire is rated for--the "do not exceed' pressure. That spec is determined by the tire manufacturer. However, when the tire leaves the tire factory, they don't know what motorcycle it's going to end up on. Therefore, the motorcycle manufacturer's spec trumps the number on the tire sidewall. BTW, the same principle applies to tires for cages, too.
Check pressures often--you only have 2 contact patches and unlike 4-wheelers, you lean on them
Good question--lots of confusion out there about that.
Well said.
Old Coot is offline   Reply With Quote
