Will these rims fit a 90 Fat Boy - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Go Back   Harley Davidson Forums: Harley Davidson Motorcycle Forum > Specific Model Areas > Softail General Discussions
Old 08-01-2009, 05:47 PM   #1 (permalink)
Can anyone tell me if the 16 inch wire spoke rims from a 2003 FLSTC will work on a 1990 FLSTF? The seller says the axle is 3/4" but I thought that after 1999 the axle was 21mm. Also, are there any other issues, like width clearance problems front or rear? Just want to make sure before I drive 60+ miles to look at them. Thanks, Bill
coolbreeze is offline   Reply With Quote
Old 08-01-2009, 07:30 PM   #2 (permalink)
Shake~N~Bake
No.
up to 1995, the bearings are Timken rollers at 3/4" ID.
1996 to 1999, 3/4" sealed bearings with different shim packs. (internally, in the hub)
2000 and up, 25mm ID sealed bearings, that are narrower than the 3/4" ones.
For the effort to buy new internal shim packs and bearings, it would be best to just find the right wheels.
Not to mention, your lower legs are 3/4" OD axle specs and 2000+ wheels are 25mm ID bearings, and the axle and your spacers/lower legs won't fit. Not to mention your brake rotors have too small of a hub diameter.
"Everyone turn away! Things are gunna get crazy..."~Ricky Bobby~
2005 FLHTCI
11 year A.M.A. member.
3 year ABATE member.
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
