I didnt have much luck, searching for a reduced reach clutch lever.
However, you could simply add a tad more free play into the lever, and that would cost you nothing, and still maintain a properly working clutch, as long as is was within reason. The bike already has a reduced pull clutch kit in it, to make the lever work about 14% easier then models prior to 2006.
The reason you're having such bad luck, is because in 2008, HD started using Brembo master cylinders and the levers have ben redesigned, including the touring series, so new parts will have to come out, however slow it's happening......
HERD meber #10
