Simple enough to fix.
Air bubbles travel UP.
Unbolt your master cylinder, leaving the brake hose in place, (undo any hose mounts) and place it on a hammer handle, or something of that diameter. Place the master cylinder on the floor, LOWER then the calipers.
Now........slowly squeeze the lever, with one bleeder open at a time. Leave the bleeder open, with your finger over it, gently. You'll begin to feel mild pressure as the air is forced out.
If you have dual brake calipers, go back and forth, a little (20 pumps) at a time.
The trick is to get the master cylinder lower then the calipers, so the air travels UP, since getting it to travel down, is much harder.
HERD meber #10
