Mirrors with turn signals - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 12 (permalink) Old 01-31-2010, 01:40 PM Thread Starter
Sportster883Bob's Avatar
Looking to install mirrors with internal led signals. Does anybody have any suggestions on what to use. I have a 09 883C.
Thank You.
Sportster883Bob is offline
post #2 of 12 (permalink) Old 01-31-2010, 02:25 PM
STAND AND FIGHT!
Nathang's Avatar
Images: 223
I asked if anybody had seen these mirrors, which come on a V_Rod Muscle,
to see it they were bright. I like the idea of signal/marker lights that high and wide,
but I've had Harley LED stuff before that was pitiful dim.
I also bought some yellow LED strips with a metal dress-up shell from Custom Dynamics
thinking I might figure a way to rig them, put them on the back of my existing mirrors,
they'd be bright, but they'd be pretty obviously stuck on.
Nathang is online now
post #3 of 12 (permalink) Old 01-31-2010, 02:52 PM
I just bought a set off of Ebay from Cycle Chopper. $120 shipped. They are out in California. Here is the link. They have a bunch of them left. Here is the link. They also have the red led turn signal in the mirror like the new trucks do. I got them a week later.
Here they are installed on my bike
Chrome Mirrors W/ Integral Led Turn Signals For Harley : eBay Motors (item 360224045793 end time Jan-19-10 22:24:21 PST)
ID:	10920   Click image for larger version
ID:	10921   Click image for larger version
ID:	10922   Click image for larger version
ID:	10923   Click image for larger version
tomseal6 is offline
post #4 of 12 (permalink) Old 01-31-2010, 03:15 PM
Poser
Osco's Avatar
Images: 7
Lemme jump in with a ?
I saw a sporty with the Front turn signals always on like my rear T sigs that I added the (ON) kit to. I don't see such a kit in the HD catalog ?? any thoughts,,,pro's,,,Con's ??
Osco is offline
post #5 of 12 (permalink) Old 01-31-2010, 08:38 PM
Harley sells these
in black clicky
...and
in chrome clicky
I think they look kinda cool... but too pricy
nickolas is offline
post #6 of 12 (permalink) Old 01-31-2010, 09:16 PM
STAND AND FIGHT!
Nathang's Avatar
Images: 223
If you were talking about the way Harley designed the circuit, if your turnsignals are not markers too, they are single filament bulbs.
That would mean in order to make them get brighter for turnsignal function, you need a dual filament socket and dual filament bulbs,
However, I have killer bright yellow LED inserts for my front turnsignals, got them from Custom Dynamics,
Here is their info sheet
Most front motorcycle turn signals are dual intensity, they light up as a low intensity running light at approximately 30% of full brightness and when the turn signal is activated they flash from the running light intensity level (30%) to full brightness (100%).
Eclipze™ LEDs are designed to increase your frontal visibility in four ways. First, the running light intensity is changed from 30% of full brightness to 100% of full brightness making you motorcycle more visible all at times. Secondly, when a turn signal is activated the LEDs flash from 100% to 0% brightness giving more contrast as a turn signal, thus increasing your visibility when you are turning. Next, because Eclipze™ uses 48 high powered wide angle LEDs, they provide more light output than standard incandescent bulbs. Lastly, because LEDs illuminate 1/5 of a second faster than standard incandescent bulbs, this provides greater reaction time for other vehicles when your motorcycle is signaling for a turn, at 65mph this equates to 17 ft of reaction distance.
It would not be difficult to make the "ON" signal from your stock circuitry make the constant "ON" lights BLINK OFF to signal the turn. You might have to run a power wire, or need a trick but inexpensive circuit from Custom Dynamics. If they don't have a more trick way, I'd rig the LED's to get power when the headlights are on.
post #7 of 12 (permalink) Old 02-13-2010, 09:49 AM
Install difficult?
I think I want these or some like them. Were they difficult to install (wiring)? I have a windsheild that I can take on/off and when on the turn signals are partially behind it. I was going to relocate to forks, but I think these look pretty cool. Is visibility good?
Thanks!
craigGA883 is offline
post #8 of 12 (permalink) Old 02-13-2010, 10:24 AM
Just passing thru
EZE RIDER's Avatar
Images: 118
Nathan did you need a load equalizer to run those LEDS?
RIDE ON!
2007 VRSCDX since
November 28 2006
Pics
EZE RIDER is offline
post #9 of 12 (permalink) Old 02-13-2010, 11:00 AM
SCHMIDTY's Avatar
The problem I've seen with LEDs is they are directional , meaning they have to be viewed more straight line to appear bright than regular filamint bulbs . Haven't seen a LED headlight yet .
SCHMIDTY is offline
post #10 of 12 (permalink) Old 02-13-2010, 11:07 AM
irate pirate
Monk's Avatar
Images: 22
Recent hi-intensity LEDs are far more omnidirectional these days. Downright blinding from straight in line, but plenty bright even in daylight from an offset viewing angle.
Tiny, some of 'em, too.
-Don
"Our intentions form the universe."
the Herd #34
Dumbass People
Monk is offline
