Oil coming from headgasket? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 38 (permalink) Old 02-28-2010, 03:24 PM Thread Starter
Did I just blow a head gasket?
There is oil seeping and leaking from the head gasket and is leaking on letting it drip on the starter. Also is spraying a light mist on the oil tank.
Also,
Would this cause me to be down about 7 or 8 HP?
tomseal6 is offline
post #2 of 38 (permalink) Old 02-28-2010, 03:50 PM
cracker's Avatar
Sounds like it... but you said dripping on the starter and misting on the tank.
That doesn't sound like it.
Was there work done on it recently? I'm asking because a common issue is installing the rocker box cover gasket. If it is inverted and installed improperly, it will blow oil as you described.
How are you determining the 7-8 hp loss?
To determine if the gasket is in wrong… take a flash light and look real close at the leading edge of each cover (the edge in the front of each jug) the gasket will be protruding about of an inch. If it is… it is in wrong.
cracker is offline
post #3 of 38 (permalink) Old 02-28-2010, 03:59 PM Thread Starter
Here are some pics of it. There is plenty of smoke being made as the engine gets hot with the oil soaked back side of cylinder. It is the cylinder closest to the seat.
ID:	12947   Click image for larger version
ID:	12948   Click image for larger version
tomseal6 is offline
post #4 of 38 (permalink) Old 02-28-2010, 04:04 PM
STAND AND FIGHT!
Nathang's Avatar
Images: 223
Looking on the bright side, if that's what it turns out to be,
...Sounds like a good time to do some head work..
Nathang is online now
post #5 of 38 (permalink) Old 02-28-2010, 04:18 PM
cracker's Avatar
A compression test will determine if the head gasket is gone. Let it cycle a few times to determine what the highest pressure is… and compare it to the other.
but check that rocker box cover gasket (the top or first gasket from the top), in the front of each jug.
cracker is offline
post #6 of 38 (permalink) Old 02-28-2010, 04:26 PM
Custom Painter
Blacksheep's Avatar
That's your rocker box gasket. About an hour job to replace. Doesn't look like the head gasket is blown to me. If the head gasket was blown it wouldn't leak upwards . All of the oil is coming from the rocker gasket and dripping down.
"If you spin a Chinese man around in circles, does he become disoriented?"
Herd member #00097
Why are they called hot water heaters?
http://s995.photobucket.com/albums/a...ksheepkustoms/
Blacksheep is offline
post #7 of 38 (permalink) Old 02-28-2010, 04:40 PM
cracker's Avatar
a rocker box gasket doesn't blow. there isn't any real pressure there. only blow by pressure from the ring gaps. that's why I asked... if any work was done on it?
cracker is offline
post #8 of 38 (permalink) Old 02-28-2010, 04:45 PM Thread Starter
Motor has aftemarket cam, thats it.
tomseal6 is offline
post #9 of 38 (permalink) Old 02-28-2010, 06:37 PM Thread Starter
Where's Dave
tomseal6 is offline
post #10 of 38 (permalink) Old 02-28-2010, 06:43 PM
The Northern Redneck
Blackdog 15's Avatar
Rocker gaskets...is there a venting problem ? EVOs will leak bad if the head vents are plugged or no vent bolt installed....on 92 and later...
If Ya Ain't the Lead Dog, The View NEVER Changes
You can Sleep when ur Dead...
Baggers RULE !!!
http://www.youtube.com/watch?v=bTrb4YGkSOU
HERD Member # 000015
Blackdog 15 is offline
