Getting a couple bogs in first gear, help? - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 06-08-2010, 09:14 PM   #1 (permalink)
1992 Sportster Bobber project
Hey, as the title states, only in first gear from time to time I get a couple bogs in a row. It seems as if it will keep doing it too if I do not shift out of it. It will rev up a few hundred rpms, then cut out, then rev up a few hundred more, then cut out all while accelerating. So on and so forth. It creates an unpleasant jerking motion that needs to be addressed. Any insight?
Also, I hear a "tumbling/rattling metal noise" coming from the engine/trans area after I shift into 4th or 5th gear under acceleration only. If I have the clutch in this noise ceases to persist. Also, with the clutch isengaged, as long as I come off the throttle, it won't make the noise. Any thoughts into that one as well? Just picked her up for a good price so I don't mind dropping a couple bucks into it if the need be. Thanks in advance folks.
Dan
Orubus is offline   Reply With Quote
Old 06-10-2010, 06:00 AM   #2 (permalink)
SCHMIDTYS's Avatar
Sounds to me like you'll need to remove the primary cover and take a look inside . Check out the shift quadrant and the drive chain tension and tensioner . You'll be able to see inside the trans somewhat by peering around the side of the trapdoor . IMO , time to get yourself a factory service manual so you'll know what you're looking at .
Old 06-11-2010, 05:25 PM   #3 (permalink)
As for the bogging?
Old 06-12-2010, 05:33 AM   #4 (permalink)
SCHMIDTYS's Avatar
Originally Posted by Orubus View Post
As for the bogging?
Might be related to the trans noise .
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
