Sissy Bar INSTALL - HELP - Harley Davidson Forums: Harley Davidson Motorcycle Forum
 10Likes
post #1 of 12 (permalink) Old 01-08-2017, 10:23 PM Thread Starter
Hello everyone,
Excuse me if I'm posting in the wrong section, just new to the forum and I am a bit confused. So, I've purchased One piece Detachables Sissy bar upright Part Number 51146-10A. I am still waiting on the Sissy bar itself but I bought the docking hardware and I installed it today. I have 2016 Sportster Iron 883. I didnt have anything to lift it with, which I've read would make the install a lot easier. But, being me, really inpatient I decided to still go ahead and do it. As expected, it was really tight back there and I was not able to fit most of my tools. Anyway, I managed to do it (see pictures below). I played around a little bit, but eventually took the stock bolts and installed the docking hardware. So, my question is do you guys think I installed it legit? I mean, is it tight enough? I was not able to tight the lock nut, I was only able to hold it while I was tightening the screw from the outside. I tight it to a point where I was not able to go any more, but I am still not sure if it is done right. Attached are the pictures so you can get an idea how I installed it. I basically managed to put the little piece inside, hold it with the pliers and unscrew the screw from the outside. Any help would be greatly appreciated, I dont want my girl to fly of the back one day because the thing is not tight enough. Thanks!
ID:	551786   Click image for larger version
ID:	551794   Click image for larger version
ID:	551802   Click image for larger version
ID:	551810   Click image for larger version
bkozhuharov is offline
post #2 of 12 (permalink) Old 01-08-2017, 11:05 PM
SoftailBilly's Avatar
Channel Locks? sigh
HRC and BikerPepe` like this.
Stay Vertical
USAF Veteran, Patriot Guard Rider.
2009 Softail Custom in Vivid Black, 3"Slip ons, SE A/C Kit, Knight Rider Xieds, SE Compensator, Fork Brace and some more chrome to polish.
SoftailBilly is online now
post #3 of 12 (permalink) Old 01-09-2017, 12:09 AM Thread Starter
Just used them tho hold the little 13mm piece from the first picture (dont know how exactly it is called). But I was holding the lock nut with it and then using the channel locks to hold it while tightening from the outside.
post #4 of 12 (permalink) Old 01-09-2017, 05:46 AM
You need, at the very least, a small cheap common floor jack a piece of 2x6 and jack up the bike, from the frame allowing the rear wheel to drop, giving you access to the nuts. The sissy bar mounts need to be tightened to specification,( you don't want the thing moving around)
Like almost everything in life, do it right, or don't do it. A loose sissy bar can be a safety item!
Silverback and FartBoy like this.
bobf is online now
post #5 of 12 (permalink) Old 01-09-2017, 06:01 AM
Asylum Inmate
bbally's Avatar
First, get Get the Harbor Freight floor lift or a more expensive one if you can afford it
Second, order the service manual for your bike, it has this information in it along with a lot of other stuff you will use.
Third, get a rolling stool from HF or another place if you have the budget for it. Save your knees and back.
Fourth, get a beer refrigerator for the garage, it helps with impatients!
FartBoy and Diz Jr. like this.
Don't be a Puss Sign up for Collision 2017 here
USMC Sgt 79-85
Malo periculosam, libertatem quam quietam servitutem
Western Colorado PGR
2003 VRSCA
2016 FLTRXS
AMA PAC Supporter
bbally is online now
post #6 of 12 (permalink) Old 01-09-2017, 06:11 AM
Negative Ghost Rider
If you have to ask... I'm guessing you already know the answer.
~ Humphrey Bogart
misinlink is offline
post #7 of 12 (permalink) Old 01-09-2017, 07:38 AM
Phdharley50's Avatar
Originally Posted by SoftailBilly View Post
Channel Locks? sigh
If someone approached my Harley with a pair of channel locks I'd brain them
Phdharley50 is online now
post #8 of 12 (permalink) Old 01-09-2017, 08:34 AM
FartBoy's Avatar
Originally Posted by bobf View Post
You need, at the very least, a small cheap common floor jack a piece of 2x6 and jack up the bike, from the frame allowing the rear wheel to drop, giving you access to the nuts. The sissy bar mounts need to be tightened to specification,( you don't want the thing moving around)!
Make ya' one of these-
$20 Bike Lift
Welcome to the Forum, from North Texas
FartBoy
and
Lucille
FartBoy is online now
post #9 of 12 (permalink) Old 01-09-2017, 02:57 PM Thread Starter
Thanks for all everyone's help, and thanks to all the smartasses it still helps in some way
Silverback, FartBoy and gusa39 like this.
post #10 of 12 (permalink) Old 01-09-2017, 05:52 PM
Sox_giantsfan's Avatar
Has to be the best starter kit description I have ever seen for a new do it yourselfer....
bkozhuharov likes this.
Sox_giantsfan is offline
