oil pressure switch and gauge - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 8 (permalink) Old 04-24-2012, 03:28 PM Thread Starter
hey guys. i want to put on a oil pressure gauge and still leave my existing pressure switch. where would i attatch my oil pressure hose for the gauge? i have a 81 sporty ironhead. thanks for any and all advise.
bobbybreach is offline
post #2 of 8 (permalink) Old 04-24-2012, 03:32 PM
You'll need a "T" fitting to run both. On Touring models, the oil guage is electric, and a dual-sensor is used that works both the guage, and triggers the light below 4 lbs.
With a light and a manual guage, you are asking to do an electrical function and an electrical function.
Unless you tap into a port somewhere else for oil PSI and leave the sending unit for the light alone.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 8 (permalink) Old 04-24-2012, 03:37 PM Thread Starter
does the "T" fitting go where the existing pressure switch is? and then the pressure switch and oil hose for the gauge just mount to the "T" fitting?
post #4 of 8 (permalink) Old 04-24-2012, 04:01 PM
Yes. T-fitting into engine, with switch and oil line in the other two openings.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #5 of 8 (permalink) Old 04-24-2012, 04:01 PM
squeekie's Avatar
Exactly.
Deep Cut Oil Pressure Gauge Kit
ID:	29099   Click image for larger version
ID:	29100   Click image for larger version
ID:	29101   Click image for larger version
Ward, don't you think you were a little rough on the Beaver last night?
2005 XL1200C Vance & Hines Staggered Short Stacks w/QQ Thunder Monster Baffles, D & M chrome spike air cleaner, 48, 185 jets, 12" Burly's, Mustang Cyclone solo seat, Progressive 412 shocks.
2009 FXSTC Vance & Hines Big Radius, V&H air filter, 16" RSD King Apes w/1 1\2" risers and 1 1/2" riser extensions, Progressive 422 shocks, Corbin seat.
squeekie is offline
post #6 of 8 (permalink) Old 04-24-2012, 04:40 PM Thread Starter
Ok great! Thanks guys. I just hope that I can fit all of that cause its in a tight spot
post #7 of 8 (permalink) Old 04-24-2012, 07:28 PM
squeekie's Avatar
Take the oil filter off. Makes it a loty easier. Still, with large hands, it's a B*tch getting it all together. The oil dripping down on parts and fingers and wrenches combined with the "no room to work" makes it hard.
squeekie is offline
post #8 of 8 (permalink) Old 04-24-2012, 07:32 PM Thread Starter
My switch is in the front of the engine and the oil filter is in the back. There's no way a T fitting is going in there. Do I need a extension or somthing?
