Rear Turn Signals - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 5 (permalink) Old 04-26-2012, 07:14 PM Thread Starter
Rear Turn Signals
I want to change my rear turn signals on a 2002 sportster 883. I bought some that are one wire. When I pulled the rear right one off, it had a purple and black wire. I can not make heads or tails of the wiring diagram in the book. My question is, What do the two wirings do and will the one wire turn signals work? Thanks for the help.
02Sporty883 is offline
post #2 of 5 (permalink) Old 04-26-2012, 08:24 PM
Addicted Since 2010
XL1200R's Avatar
Images: 38
One is a ground I think.
Not sure though.
"Mr. Lahey is this you talking or the liquor?"
"Randy...(takes a swig)...I am the Liquor!!!"
XL1200R is offline
post #3 of 5 (permalink) Old 04-26-2012, 08:31 PM
Newer turn signals on HD have a ground wire. Black is ground, purple is positive.
On the older ones, the single wire is positive, and the lamp grounds via contact when mounted. You can see the ground in the socket routes to the inside of the lamp housing.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #4 of 5 (permalink) Old 04-26-2012, 08:42 PM Thread Starter
So, the turn signals that I have are for an older sportster. They will not work?
post #5 of 5 (permalink) Old 04-27-2012, 02:12 PM
Official COA Hunter
dcoley's Avatar
If they are single wire you should be able to attach a ground wire someplace or replace the inside socket with one with two wires.
2003 XLH1200 USAF Vet.
"I think myself that we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." - Thomas Jefferson
dcoley is offline
