» Site Navigation |
» » » » Motorcycle Forums
» Our Partners |
09-23-2012, 12:06 AM
#61 (permalink)
Originally Posted by modular
They did.......of course everything was "normal".
I don't think this is an issue with my grip as I have tried every different grip I could think of to see if it went away. This is a Sporty so it's got cables. I have had an Iron (bought new), XR1200 (bought new) and a Street Rod and non of them did this. The '03 SV1KS I had never did this, nor did my '77 GS750. First bike to ever have this issue.
It is not your grip. I have the same problem with my 2012 xl1200c
really annoying. It is like the bumps jar the efi.
09-23-2012, 12:39 AM
#62 (permalink)
Good news!!!
It seems the pull cable was not seated all the way into the throttle body and up against the spring. Snugged that up and re-checked the cable adjustments per the manual. Both the push and pull cables were off by about 4-5 turns too tight each. Took it for a spin and hit ever manhole cover and rough patch I could find. Dead stable! It even picks up better due to the throttle opening up all the way.
Thanks again for all the help folks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I'd rep all of ya if we had that here.
Modular, when you say "per manual", is this the info under Throttel Control Pg. 1-67. Fig. 1-84 ? If I adjust according to manual's specifications will it fix the problem ,or is this someting not mentioned that you noticed? Any details you might provide will be appreciated.
09-23-2012, 05:41 AM
#63 (permalink)
Bubblehead
I used the instructions in the service manual. I thought it was page 2-30.........or 1-30, crap I can't remember. I would start with doing what I did and see what that does for it.
Ohio Patriot Guard Rider
09-23-2012, 08:36 AM
#64 (permalink)
It's your seating position, arm position and grip. When you hit a bump or dip your elbows are bending causing you to throttle up.
 SUA SPONTE
09-23-2012, 08:45 AM
#65 (permalink)
Maybe, but the OP said he also needed to adjust the throttle properly.
09-23-2012, 08:48 AM
#66 (permalink)
Bubblehead
This......and it's all better.
09-25-2012, 07:57 PM
#67 (permalink)
Tell me, How to adjust the throttle properly? I'm curious. If he's twisting the throttle in a dip or a bump there's no adjustment for this, it's physical. OH ya, the OP states he HAS the throttle adjusted properly. RE-READ it.
 SUA SPONTE
09-25-2012, 07:59 PM
#68 (permalink)
Greasy Member
Because if the throttle and Idle cables are adjusted too tight, there's no free-play and any movement what so ever results in throttle input.....
The throttle tube is adjusted like most tings on the bike, and require a specific method to do it, with a desired result.
The correct methos is here..:
Throttle Cable Adjustment
Football Season is over....
Praise the Lowered!
11 year A.M.A. member.
4 year PA ABATE member.
09-25-2012, 08:03 PM
#69 (permalink)
RE-Read his post where he said how he solved his issue. He went back and found it was not correct.
Follow along, that way you won't sound like a giant *&^(.  s
He explained in his his case what he found to be the problem and the solution that worked for him.
11-18-2012, 10:59 PM
#70 (permalink)
my '12 1200c does the same thing at lower rpms. They don't like to be lugged.
| Thread Tools |
| Display Modes |
Linear Mode
