Jumpy throttle over bumps - Harley Davidson Forums: Harley Davidson Motorcycle Forum
Old 09-18-2012, 12:10 PM   #1 (permalink)
Bubblehead
modular's Avatar
Angry Jumpy throttle over bumps
This is my first Harley that has had this problem. On streets/freeways that are not in the best condition or have bumps as I hit them it makes me crack/bump the throttle. This has become worse since installing drag bars using the stock C curved riser but was there to a lesser degree with the stock bars. I have the throttle cables adjusted correctly, I'm not leaning on the bars nor white knuckling the grips. This is getting very frustrating and I am at a loss of what to do next.
Any thoughts? Bike in question is a 2012 XL1200C I bought new.
Ohio Patriot Guard Rider
modular is offline   Reply With Quote
Old 09-18-2012, 12:11 PM   #2 (permalink)
Loosen your grip...
Old 09-18-2012, 12:14 PM   #3 (permalink)
Bubblehead
modular's Avatar
Yeah, did that. I've done everything from letting the grip float in my hand to a tight drip to hold it steady to holding it with 2 fingertips. Again, this is the only Harley that has done this.
Old 09-18-2012, 12:21 PM   #4 (permalink)
Huh... It's a 2012? If so warranty maybe, at least have dealer look at it.
Old 09-18-2012, 12:23 PM   #5 (permalink)
Baldrick's Avatar
Originally Posted by misinlink View Post
Loosen your grip...
Like what he said - relax. Could be this is the first Harley you've had with a properly lubricated throttle cable so it moves easier (or maybe it's a fly-by-wire). If it's really a problem try tightening the friction control a tad so there's more resistance. Be careful though, you still need the throttle to close all by itself!
Baldrick is offline   Reply With Quote
Old 09-18-2012, 12:29 PM   #6 (permalink)
Bubblehead
modular's Avatar
They did.......of course everything was "normal".
I don't think this is an issue with my grip as I have tried every different grip I could think of to see if it went away. This is a Sporty so it's got cables. I have had an Iron (bought new), XR1200 (bought new) and a Street Rod and non of them did this. The '03 SV1KS I had never did this, nor did my '77 GS750. First bike to ever have this issue.
Old 09-18-2012, 12:53 PM   #7 (permalink)
Poser
Osco's Avatar
Images: 7
Modular,,
I'm going out onna limb here,,,off the wall thoughts...
Go for another gear,,
Get your riding position looked at, re-evaluated, Are your elbows bent ?
Straight arms will do that.....
I bounced over some bone shakers at various speeds n throttle positions...
Only time I can remember that happening Is when I gripped hard....
They said at HD everything was normal huh,,,
Sorry But trust Is earned, not given...
My next step would be,,,
Get the HD service book and take the whole throttle rig apart,
Inspect It myself for cable defects, binding, Improper routing....
My 2008 1200R throttle feels just like the Dyna I test rode,
and my buddies 2007 1200C,,,
Yeah bran spankin new bike and you've been on other Harleys,,,I'd take It apart.
After checking everything I'd bet the new bars are causing It,,ya may need different length cables....
We are Legion
Osco is offline   Reply With Quote
Old 09-18-2012, 01:01 PM   #8 (permalink)
Bubblehead
modular's Avatar
I had the throttle apart last weekend. All is good there. My arms have a bend to them with no pressure on my hands.
As far as cables go....I went a little lower to drag bars but none of the control cables are out of shape. It also did it with the stock bars but to a lesser degree. This is gonna suck if it's the bars causing this.........
Old 09-18-2012, 01:09 PM   #9 (permalink)
Poser
Osco's Avatar
Images: 7
How did the cable move inside the sleeve ??
I'm thinkin,,a bur,,out of sight,,,,,,,
the spring damaged/stretched, maybe an amount you missed ??
Know a Good Indi ???
Your dealer Is wrong,,,It ain't normal at all.
We are Legion
Old 09-18-2012, 01:14 PM   #10 (permalink)
Bubblehead
modular's Avatar
By spring, you mean on the throttle body for the push cable?
