Engine Run-on - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #1 of 21 (permalink) Old 09-19-2012, 08:01 AM Thread Starter
Fuzzy66's Avatar
Images: 6
Engine Run-on
So, I get into work this morning and shut off my bike and the engine continues to run for about 4 sec.
I've looked around a bit and see when folks have discussed this on other forums. I've seen people blame:
1. poor gas.
2. too advanced timing. One poster on another board suggested that Harley ships the Sportster with the timing advanced 2 degrees further than it should be.
3. too rich of a slow jet.
I run 93 octane and always have. I don't think I buy the timing too advanced by factory theory.
When I replaced my drag pipes with stage I mod stock pipes, I was running too rich and had to close down the jet. So I am running 1-3/4 turns out on a .48 slow jet. I guess I could re-jet it back to the .45. But I haven't had any issues until today.
Any sage advice out there?
Thanks.
Congress on fiscal responsiblity:
"Somebody's got to go back and get a shitload of dimes?"
Fuzzy66 is offline
post #2 of 21 (permalink) Old 09-19-2012, 08:06 AM
Run-on is caused by:
Fuel supply....with excessive heat to ignite it. (That's why it's called "Dieseling".)
The engine can't run without fuel.
Fuel doesn't burn without spark/heat.
Venturi vacuum can pull fuel from carb.
Start looking at heat related issues, like leaking intake seals, or something creating excess heat. (Lean)
Timing can contrinbute as well, but so can plug heat range and gap.
R.I.P. Rubberdown. 1971-2012
2005 E.G. Classic
S&S 510 cams
Baisley Oil pump spring
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #3 of 21 (permalink) Old 09-19-2012, 08:08 AM
MPG'S? Who gives a
Craiger's Avatar
Images: 11
Gap too wide or closed Dave ?
08 FLHTC. Breathing well and getting lots to drink.
Craiger is offline
post #4 of 21 (permalink) Old 09-19-2012, 08:11 AM Thread Starter
Fuzzy66's Avatar
Images: 6
I did just install SE plugs and wires last weekend. Think that's a contributor?
Fuzzy66 is offline
post #5 of 21 (permalink) Old 09-19-2012, 08:11 AM
Too close/tight. Causes pre-detonation.
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #6 of 21 (permalink) Old 09-19-2012, 08:12 AM
Did it do this BEFORE the plug/wire install?
2005 E.G. Classic
S&S 510 cams
CYCO tensioners
V&H Fuelpak
SE 3.5" pipes
K&N filter
Fueling lifters
S&S adj pushrods
Swingarm stabilizer
Dave63 is offline
post #7 of 21 (permalink) Old 09-19-2012, 08:16 AM Thread Starter
Fuzzy66's Avatar
Images: 6
No, I recall once the engine might have made like a 1 revolution run-on after engine shut off. But it was a really hot day, so I didn't think much of it.
Fuzzy66 is offline
post #8 of 21 (permalink) Old 09-19-2012, 08:31 AM
Hit it she goes boom
GotGold's Avatar
My 98 Sporty had a CV carb I'd have this happen and cut the idle speed. Low jet could not be adjusted, screw was stripped. Can you drop your idle speed down any??
"Our lady of blessed acceleration don't fail me now."--- Elwood Blues
"What does not kill you makes you stronger..... except for bears, bears will kill you."
"Give her full throttle till ya see God... then back off"--- Some guy in a bar.
GotGold is online now
post #9 of 21 (permalink) Old 09-19-2012, 08:40 AM Thread Starter
Fuzzy66's Avatar
Images: 6
Running about 1020 rpm on idle. Heard alot of scare stories about dropping idle too low. Engine damage and such. So, I don't think I want to go any lower.
Fuzzy66 is offline
post #10 of 21 (permalink) Old 09-19-2012, 08:46 AM
GotGold's Avatar
Time for an expert here but unless you've got EFI I don't understand why your idle is up that high. Just my .02
