sporty doesn't want to cooperate - Page 2 - Harley Davidson Forums: Harley Davidson Motorcycle Forum
post #11 of 35 (permalink) Old 11-14-2012, 11:51 AM
أنا كافر
Kainam's Avatar
Images: 150
Originally Posted by squeekie View Post
You missed one.
Ha! I had to remove one cause the forum only lets us put 10 pics in a post!
Mala Ipsa Nova
Psalm 144:1 Luke 22:36
'05 Carbed Night Train
111 rwhp, 112 rwtq
Best 1/4 ET 12.557s
Best 1/4 MPH 108.59
Kainam is online now
post #12 of 35 (permalink) Old 11-16-2012, 11:49 PM Thread Starter
well it's back to square one, took it over to my sisters to help her move and it wouldn't start up for the return trip, heading back this weekend to start running through and testing the systems, hoping for a bad VR simply because i don't want to tear the bike down to replace the stator. unfortunately money is tight so sending it to a shop is out of the question, guess you gotta learn somewhere huh?
fox_doc8403 is offline
post #13 of 35 (permalink) Old 11-17-2012, 06:55 AM
Negative Ghost Rider
Again, start simple.
There is a very specific way to install the battery on the 04 up sportsters. If not properly followed will result in the battery negative cable loosening up at the terminal every time .
1) Remove the battery hold down strap .
2) Remove positive cable from terminal .
3) Disconnect negative cable from the top of trans .
4) Slide battery out pulling the negative cable with it .
5) Tighten negative cable to battery terminal with cable pointing down.
6) Start battery into place feeding negative cable back in and down to trans .
7) Reconnect positive cable to terminal and install hold down strap .
8) Reconnect negative cable to top of trans .
9) Thank SCHMIDTYS for the write up
If that all looks Kosher, then start going through the charging system.
Charge System Diagnostics
~ Humphrey Bogart
misinlink is online now
post #14 of 35 (permalink) Old 11-17-2012, 09:37 AM
SCHMIDTY's Avatar
Always disconnect the negative battery cable first and reinstall last. That way if you accidently touch the positive to any metal it won't short to ground !
SCHMIDTY is offline
post #15 of 35 (permalink) Old 11-17-2012, 12:58 PM
Hit it she goes boom
GotGold's Avatar
Which results in a brief lesson on how to arc weld your tools or your bike...... pls don't ask me how I know this...
"Our lady of blessed acceleration don't fail me now."--- Elwood Blues
"What does not kill you makes you stronger..... except for bears, bears will kill you."
"Give her full throttle till ya see God... then back off"--- Some guy in a bar.
GotGold is online now
post #16 of 35 (permalink) Old 11-17-2012, 11:47 PM
02sportytex's Avatar
Come on we gotta have that story
02sportytex is offline
post #17 of 35 (permalink) Old 11-18-2012, 08:59 AM
GotGold's Avatar
Its a SHORT story.... pun intended..
post #18 of 35 (permalink) Old 11-23-2012, 04:03 PM
I see what you did there
post #19 of 35 (permalink) Old 11-23-2012, 07:02 PM
THE ROAD's Avatar
Images: 29
So , tell us now , is your bike an EFI or a carb . ?
THE ROAD is offline
post #20 of 35 (permalink) Old 11-24-2012, 02:03 AM Thread Starter
it's carb, I was able to go through today and the stator checks out the connections are all clean and secure so the only thing I'm left to think is that the voltage regulator is the culprit. Heading down tomorrow to shell out the cash to get up and running again.
